Old 10-03-2011, 10:38 PM   #1
UBLUZIN
325/80/16 on stock wheel?
Will a 325/80/16 fit a stock 8 lung wheel? Anyone put that size tire on a stock chevy 8 lug wheel?
UBLUZIN is offline   Reply With Quote
Old 10-04-2011, 07:17 AM   #2
b454rat
Re: 325/80/16 on stock wheel?
They call for a skinny wheel so should work fine.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 10-04-2011, 08:12 AM   #3
Wow! Never even heard of that size. Why did they stop calling them what they are so we know what size they are? How tall and how wide are they and who makes that size?
I'd imagine it's wide for a stock wheel since 285/75s are a bit wide and by the time you're at 325,even in the slightly taller/skinnier profile,they'd be wider.
Old 10-04-2011, 10:18 PM   #4
UBLUZIN
Falken makes them. Falken wild peak. They measure 36.8". Im currently running 38" boggers and dont wan to mess them up on the street. Im looking for a tall A/T tire that will fit a stock 8 lug wheel...
Old 10-05-2011, 12:44 AM   #5
Your41Plague12
Your41Plague12's Avatar
How wide is this stock wheel you're referring to? 325 mm wide across the tread isn't exactly narrow. It's like a 13" wide tire. I hope the stockers you're running are 8" wide or so.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 10-05-2011, 07:30 AM   #6
b454rat
I was thinking it was the military tire, but since the tire is tall and skinny, a stock wheel will work. Or get 8" ones. I'm gonna have to check into these....
Old 10-06-2011, 06:04 AM   #7
Isn't a 325 more like a 14.40? I'd want a 10-12" wheel for that. No way those will be right on a stock 6-7" wheel. Like I said,285s are about the limit. They should be on an 8" wheel. Those tires don't sound tall and skinny to me. I ran 14.50/37s for years and they are the same profile as a 12.50/35. I used 10" rims. Then,Super Swampers came out in 13/37s but I still ran those on 8"...last picture:
Old 10-06-2011, 07:34 AM   #8
b454rat
With a tire that tall it's really not gonna make that much of a difference...I'd run an 8" myself....
http://www.ntwonline.com/webpage.cfm...ategory_ID=765
Old 10-07-2011, 07:05 AM   #9
Whatever, I wouldn't. It will crown and wear in the center and be less stable being pinched in. I know tire manufacturers would recommend 10-12". It's the width that matters,not the height. But,with height comes more sidewall sway and safety is a concern. Either way,there is no 8" stock wheel in 16" anyway.
