Old 10-05-2011, 02:43 PM   #1
86k20mudddigger
rims
i am curious on what rims will fit 1 ton running gear ive got 16.5s but there not the best to drop tire presure due to popping the bead. but dose any one know the smallest rim i can run?
86k20mudddigger is offline   Reply With Quote
Old 10-05-2011, 04:11 PM   #2
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
Re: rims
you can run 15's if you grind your calipers up front and get the proper offset, otherwise you can go with 16's without any modifications
Overkill is under rated, Redneck Customs Truck Club Hudson, IA
"Clifford" 83 Chevy K20 4x4, Mudder 7" lift rolling 44's
"Basterd Child" 86 Chevy K30 4x4 crue cab Dule, 7.3l international WIP
'00 ex-cab Silverado 4x4 DD
I hate red trucks but you can't tell by looking at what I own
Tex_50613 is offline   Reply With Quote
Old 10-05-2011, 09:46 PM   #3
ghettoluxury
ghettoluxury's Avatar
Re: rims
I run 15's with alot of grinding to the front calipers. 16's are direct fit and can be aired down nicely.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-05-2011, 10:29 PM   #4
Redcap
Re: rims
Depends on the backspace of the wheels. I know guys running customs with 2" backspace that didn't grind at all and others running standard 4" backspace that ground a bunch.
Redcap is offline   Reply With Quote
Old 10-05-2011, 10:49 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: rims
Yep same here just depends on how much work you want to do to make them fit on there.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-13-2011, 08:54 AM   #6
duallyjams
duallyjams's Avatar
Re: rims
17" rims give you a lot of tire choices.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
