Closed Thread
Old 10-08-2011, 09:18 PM   #1
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
69 3/4 ton Dana 60 rear
$300 shipped MIDWEST!!!- COMPLETE AXLE Dana 60 rear end 1969 3/4 ton(8 lug) with leaf suspension .[/COLOR] can not get number off but pretty sure 4.11 gears. I counted the teeth by hand!!!! lol this is off my 69 so I KNOW it performs excellent.also have entire rear drum brake setup up for grabs with new shoes,wheel cylinders and adjuster screws.. pics to come
Brushed aluminum color cover and housing was degreased and prepped with zinc phosphate the coated in POR-15
TALK TO ME!!!
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline
Old 10-09-2011, 12:45 AM   #2
HeavyMetalChevy
Just a Member
Re: 69 3/4 ton Dana 60 rear
Plenty views... talk to me...
TH400(3rd)
Old 10-10-2011, 02:44 AM   #3
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 10-11-2011, 11:03 PM   #4
HeavyMetalChevy
Just a Member
Drum break setup... new wheel cylinders, Hard braklines,connectors,rubber, shoes, and adjusters... Will sell separate form axle if wanted.
TH400(3rd)
Old 10-13-2011, 02:53 AM   #5
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 10-14-2011, 01:49 AM   #6
HeavyMetalChevy
Just a Member
TALK TO ME... lots of views not one offer????
TH400(3rd)
Old 10-14-2011, 03:43 PM   #7
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 10-14-2011, 07:12 PM   #8
BCOWANWHEELS
How much for just the 4.11 gear set ? Also is it open diff ?
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline
Old 10-14-2011, 07:52 PM   #9
HeavyMetalChevy
Just a Member
I will have to check pricing...Never sold any yet... And yes it is open...if it was posi or had a locker I would def. be keeping it..Sorry for not being more specific..I will get back to you promptly on price.
Thanks...
Duane..
TH400(3rd)
Old 10-16-2011, 07:53 AM   #10
HeavyMetalChevy
Just a Member
let me know if you want still
TH400(3rd)
Old 10-25-2011, 12:23 AM   #11
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 10-25-2011, 10:22 AM   #12
goregalore
goregalore's Avatar
This is Kind of Sad,
I need the rear wheel cylinder push rods.
They are not available new. I will take the wheel cylinders, and if necessary I will buy all the brake components to get the. I purchase all the components from Napa. And you know what. I am afraid they don't fit right.
The shoes are 2.5 in wide. and the drums are 12" id. Is this what you have?
goregalore is offline
Old 10-25-2011, 01:04 PM   #13
HeavyMetalChevy
Just a Member
I will get back to you as soon as I can with that info buddy...Short day and moving FAST!!! I will get it to you though... I have a 71 rear too I will check as well.
Thanks,,,Duane
TH400(3rd)
Old 10-25-2011, 07:47 PM   #14
goregalore
goregalore's Avatar
I await with baited breath for your response.
I am having more trouble than I ever thought I could have for 4 wheel cylinder push rods for this heavy duty rear end.
Thanks,
Old 10-25-2011, 08:40 PM   #15
HeavyMetalChevy
Just a Member
I GOT YOU MAN!!!!! I will pull off the cylinders tomorrow and have you hooked up!!!! I just noticed you are from Indiana as well... Friend request required sir!!!
TH400(3rd)
Old 10-25-2011, 09:21 PM   #16
goregalore
goregalore's Avatar
That is awesome,
Friend request accepted also
Old 10-31-2011, 09:00 PM   #17
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 11-05-2011, 12:10 AM   #18
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 11-16-2011, 12:48 AM   #19
HeavyMetalChevy
Just a Member
ttt $200 for Dana6o complete rear new shoes,adjusters, wheel cylinders, line hard and soft,
$200 for complete SOLID leaf included 3/4 ton 5 leaf suspension with great shackles and eye bushings
TH400(3rd)
Old 11-22-2011, 01:19 AM   #20
HeavyMetalChevy
Just a Member
ttt
TH400(3rd)
Old 01-12-2012, 01:11 AM   #21
HeavyMetalChevy
Just a Member
can get these shipped cheap guys!!! Solid Dana60 rear here drum to drum $200
TH400(3rd)
Old 01-12-2012, 02:06 AM   #22
454stepside
heavy if your looking for a dana 60 posi i have one from a 67 leaf spring truck for sale it 4:10 gears
454stepside is offline
Old 01-12-2012, 02:28 AM   #23
HeavyMetalChevy
Just a Member
Hey Hey now... I think have a Eaton ho52 on my 70 c-20 with a posi but i am not too familiar with Eaton setups still. I know they are quite different than a typical posi setup with the spring mechanism and two ring gears. It is also a coil rear. I do however have a 71 swb leaf but it is a C-10. I would have to check the inside plate to plate measurements to see how they would mount up.. Any insight would be greatly appreciated. You know the width of yours and approx how many miles it has on it???
Thanks man!
TH400(3rd)
Old 01-12-2012, 02:30 AM   #24
HeavyMetalChevy
Just a Member
also do you have it for sale on forum and why you parting with it?
TH400(3rd)
Old 01-12-2012, 03:06 AM   #25
454stepside
I am sorry I am wrong its not from a 67 its from a 70 I think got it from my friend Ernesto. I have no clue on miles I can get you some measurements tomorrow if you want. Yes its for sale on the forum I can pull it to the top for you if you want. I can also get you some pics if needed. It is currently under a frame thats gonna be a trailer but I have another rear to put under it. As far as i know everything is good on the rear. Everything spins freely.
Closed Thread
