Old 10-10-2011, 12:59 PM   #1
Booya
Booya's Avatar
Emergancy brake cables with lift
Hi guys,
So I’ll give you a little history of my build, it’s a complete frame off build, 1972 short box 4x4 1/2 ton. The frame and all suspension components have been blasted and painted and I’m at the stage of reassembly. I have installed a 4” lift kit and I’m starting to hook my rear emergency brake cables back up, and they are about an inch too short to the bracket. Looks like I need to go from a 48” to a 52-54” cables for a nice fit that’s not stretching them, any suggestions besides having new ones made? Maybe someone has found pre-made ones that will fit and are at the longer length. I’m assuming normally the cables just get stretched during a lift install when they are still attached to the brack? Thanks Bill
Booya is offline   Reply With Quote
Old 10-10-2011, 07:22 PM   #2
71blazerdetroit
Re: Emergancy brake cables with lift
http://67-72chevytrucks.com/vboard/s...d.php?t=309806
covered a few different ways in the link.
I was planning on hitting in-line tube since their down the street from me, but I goofed and threw out my e-brake pedal assembly, thats a whole other story.
71blazerdetroit is offline   Reply With Quote
Old 10-10-2011, 09:34 PM   #3
Booya
Booya's Avatar
Thanks, I have a feeling in-line tube is where I'm going to end up at....
Old 10-10-2011, 09:35 PM   #4
turp mcspray
turp mcspray's Avatar
Did you trying routing them over the springs? I have 8" lift skyjacker springs in the rear of my 72 blazer, and I am still running the stock cables without any problems.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-10-2011, 10:13 PM   #5
mstrav1973
mstrav1973's Avatar
If you need to look at mine let me know, im in Meridain and have a 4" lift
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 10-10-2011, 11:34 PM   #6
Booya
Booya's Avatar
Turp Mcspray, I did and they are still too short....
mstrav1973, thanks for the offer and nice truck by the way... So was yours connected when you installed your lift and how tight are they? I went out and took a pick of the left side since I havent removed it yet, as you can see how close it is when pulled tight. It might be best just order a 2-4 inch longer ones just so they arnt so tight....
Old 10-11-2011, 07:30 AM   #7
With a 6"lift on a '72 there was no way the stock cables could work. That's when I went to Inline Tube. I also wanted travel,so I added some more length.
Old 10-11-2011, 09:16 PM   #8
turp mcspray
It's been a long time since I installed the lift. Maybe I relocated the cable mounts. I do know that my e-brake still worked, and I still had the stock cables. I will have to crawl under there and look.
Turp Mcspray
Old 10-11-2011, 10:57 PM   #9
mstrav1973
mstrav1973's Avatar
Heres mine. You may gain some slack once you get the cab, bed and engine installed. Just the roller frame doesn't put much weight on the springs.
Matt
Old 10-11-2011, 11:25 PM   #10
Booya
Booya's Avatar
Thanks guys, Matt I was thinking the same thing last night, I think I'll unbolt the axle and get it hooked up and go from there. Bill
