Member since 2000
it has about a 1/2 inch gap between the intake manifold and the flange that suppose to seat it self? any thoughts? thanks
Progress = 0%
Crank the engine over a little. There is a slot on the oil pump drive shaft that has to line up with the tab on the distributor shaft. Just turn it over and it'll drop down.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
or try using a long screw driver to turn the shaft
72 chevy 3\4 ton 4 speed 4x4 84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories) 1999 suburban 4x4 1982 chevrolet S-10 V-8 (Thanks uncle EARL) |
![]() Join Date: Jun 2002
do you have a chevy HEI? I have one that is about .75 longer than normal. I think it is a olds or pontiac. It would have the gap you describe if installed on chevy. Measure your HEI from intake flange to lower end of unit. If it is chevy, then your oil pump drive shaft needs clocked to allow the tang on bottom of HEI to engage. (this misalignment should only hold HEI out about 1/4")
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
Member since 2000
GOT IT thanks to AIM and Slammed67 help. thanks every one else for helping out too.
#6 | |
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
Ed, you are right in that it would throw off the timing if you cranked over the engine to get the distributor to drop. You have to do like you said, only turn the oil pump to get it aligned. As trailwart said, a long screwdriver will work, and a long scraper screwdriver will work better, with the wide blade. Also you can use an old distributor shaft, as it marries up well.
If you just pulled the distributor without worrying about #1 on top dead center, then the distributor has to go in the exact same way it came out, with the engine at the exact same place. That's why you can't crank the engine. If you're building an engine, or for some other reason are starting at #1 cylinder at TDC, then the distributor must be aligned for TDC. Again, you can't crank the engine or you'll lose TDC. Only way to do it is to turn the free-spinning oil pump tang at the bottom of the distributor pit until it lines up with the angle on the distributor slot. Then ease the distributor in. You can wiggle the distributor a little once it's close, but not enough to throw it off by a full cylinder.
RLTW 70C10 72K10 72K10 Cheyenne 72C10 Cheyenne Super |
Spank 'em if you got 'em!
I've always turned it over to get the distributor to drop in. I never can seem to get it in right the first time anyway, always one tooth off. Regarless, how is turning it by hand better than hitting the starter for a second? The distributor is on the gear part way (at least mine is), so you are just turning it to line it up with the oil pump, right? Also, isn't the timing always off after you pull the distributor? I can never get mine in exactly the way it was before and I always have to time it when I'm done. I'm just curious to know a little more about this.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
Thing about getting the distributor to drop when you do the install is to keep in mind you are not taking a straight shot at it. Since the gears are at an angle, you have to think about the approach. It is best to get the oil pump lined up using a old distributor shaft or screw driver based on where it looks like the distributor will line up.
I've found that a point of reference on the valve cover somewhere is about the best way to START with the distributor install. This will give you (again with the angle) a target to shoot for with the install. I doubt very seriously if it is possible to hit perfect timing with an install, at least not consistently. Marking the distributor shaft body and intake manifold might prove me wrong though. Thing is, my marks usually don't stay or I'm replacing the intake, distributor or some other referencable part when I pull the distributor. One more thing, It seems to me that I have to go one more tooth with an HEI than I did with the points distributor to get it to timing right. Short of really twisting it up, I pull the distributor and move it one tooth. This also helps keep the wires going to more or less the correct spot shown in shop manuals.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
#10 | |
1970 C10: 2WD, LWB, 350, 350 auto, Headers, Duals, Edelbrock 1406 with 2101 intake, and optional rust. |
When you turn the oil pump tang by hand, you are not moving the engine and you are not changing the position of the cylinders. When you bump the engine, you are changing the position of the cylinders. The distributor and cylinders have to be exactly aligned to run right. One tooth off and you get backfiring and really poor running.
Fabricate till you "puke"
If the dist teeth are started into the cam gear, you can hold a little pressure on the dist & have somebody bump the starter.....assuming that the dist is stared in in the proper spot(slightly CC of where it will end up bolted down)......the dist will drop into the oilpump shaft, & will not affect the timing. If you turn the eng with the dist out.....thats another story! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
#13 |
Semper Fidelis
Did you have the engine apart? Iknow it is unlikely but it happend to me last year. I put in a big block pump driveshaft that I had on the workbench when I put my 307 together. Probably not your issue but it is possible.
72 Chevy C 20 with 402 For sale 85 GMC K2500 ![]() 83 Trans Am Cedar City, Utah (Missouri Native) |
#14 | |
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
#15 |
I don't even hold presure on it 'cause I'm usually by myself and have to hit the starter. If I ever pull my distributor and get it in right the first time I will be the happiest man alive, at least for a couple minutes.
