Old 10-21-2011, 12:11 PM   #1
chevy355
Question vortec heads
I have a chance to get vortec heads for free off my bro's truck. Its a 1998 k2500 with a 350. I wanted to put the heads on a 70s 350. Will my intake work? Any modifacation id have to do? thanks
Matt
1986 chevy K10 355, sm465/np208, 14FF/dana 44
1984 chevy K20 350, th400/np208, 14SF/10 bolt
chevy355 is offline   Reply With Quote
Old 10-21-2011, 12:16 PM   #2
nobull2
nobull2's Avatar
Re: vortec heads
you will have to change intakes and exhast manifolds
nobull2 is offline   Reply With Quote
Old 10-21-2011, 12:22 PM   #3
Mr. 250r
Mr. 250r's Avatar
Re: vortec heads
Which vortec heads are they if I'm correct there's 2 of them the heavy duty trucks apparently had the lesser flowing heads of the two I can't remember the #s but a Google search would bring up a ton on them
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-21-2011, 12:34 PM   #4
RUSHNBOBO
Re: vortec heads
Some ¾- and 1-ton trucks came with Vortec heads equipped with a specially hardened exhaust seat that kills low- and mid-lift flow. Casting number 10239906 should be avoided. Look for casting number 12558062....
read this thread, it answers everything you need to know and more about Vortecs
http://67-72chevytrucks.com/vboard/s...d.php?t=485197
RUSHNBOBO is offline   Reply With Quote
Old 10-21-2011, 12:35 PM   #5
chevy355
Re: vortec heads
Im not sure what the head numbers are, they are still in the truck
Matt
Old 10-21-2011, 01:18 PM   #6
RUSHNBOBO
Re: vortec heads
All early Vortec heads have part number 125508060. But these are made from two different castings 10239906 or 12558062. The difference between them is that the 906 uses hard seat inserts and the 062 uses induction hardening. Either makes a production L-31 truck head. The 906 is usually found on heavy duty trucks. Both "060" heads use 1.94/1.50 valves with a 165-170 cc intake port.
Exhaust bolts up intake does not .....production L31's need a 8 bolt style intake. Gm "bowtie vortecs" special parts dept heads, have a dual bolt pattern for intake 8 or 12
Old 10-21-2011, 01:54 PM   #7
jrcaprai
Re: vortec heads
Vortec Cylinder Heads: The Definitive Guide
http://www.nastyz28.com/forum/showthread.php?t=56505
jrcaprai is offline   Reply With Quote
Old 10-21-2011, 04:30 PM   #8
BigBlocksRule
Re: vortec heads
The only 906's to avoid are the very first ones. After that, GM used smaller press-in seats that didn't hang so far out into the port.
Don't even try to redrill your intake to work, vortec ports are raised .100 and they're taller and narrower than conventional. Check sleazebay, you can generally get a good dual plane vortec intake for around $100.
Make sure you read about retainer to guide clearance issues, particularly if you're going with a cam with over .450 or so lift at the valve.
Great heads, spend a few minutes with a Dremel or die grinder working the ridge in the exhaust short turn. It's a sharp edge and doesn't take but a few minutes to blend it into the runner. Blend the seats into the ports as well.
DON'T TRY TO RESHAPE THE PORT, JUST BLEND THE CUTTER/MACHINING LINES!!!
BigBlocksRule is offline   Reply With Quote
Old 10-21-2011, 04:38 PM   #9
RUSHNBOBO
Re: vortec heads
Use Crane Cam’s 10309-1 drop-in valve spring and retainer kit which is good for .550” lift with no machining.” about $160 bucks
Old 10-21-2011, 05:11 PM   #10
RUSHNBOBO
Re: vortec heads
If you can pop off one valve cover it's right here
Old 10-21-2011, 06:05 PM   #11
jojoman
Re: vortec heads
whta would the front of the vortec head look like pattern wise in front. you know how they got a design infront. cuz i really aint trying to open up the valve cover cuz i got this luck with gaskets that man let me tell you.
jojoman is offline   Reply With Quote
Old 10-21-2011, 06:20 PM   #12
RUSHNBOBO
Re: vortec heads
906
062
Old 10-21-2011, 07:21 PM   #13
spudz
spudz's Avatar
Re: vortec heads
Just intake, you dont need new manifolds..
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
2500, 350, heads, k20, vortec
