Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 11-05-2011, 01:53 AM   #1
Mike Bradbury
Mike Bradbury's Avatar
Upkeep of the intake
I have a non-polished aluminum performer intake. When I bought it there was a nice satin finish on the new aluminum casting. was not long before it started to look pretty bad and just a dingy old gray aluminum look.
I am wondering what product or process keeps the bumpy aluminum casting looking new?
I have toyed around with powder coating it but am still on the fence. I have seen it done and it looks good but the raw satin cast looks good too.
The day I installed it
After about 1000 miles this is what it looked like
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 11-05-2011, 06:41 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Upkeep of the intake
You've got to know what I'd recommend, powdercoat. I did this one for a member here. It's a silver basecoat with clear topcoat. That seals the pores and smooths the casting out so you can wipe any spills or leaks off.
Old 11-05-2011, 08:53 AM   #3
68Stepbed
68Stepbed's Avatar
Paint or powdercoat are about your only options to keep it looking good. The rough cast finish allows dirt and grime to build up in the porous pits, and also stains the aluminum, so it's very hard to clean properly without media blasting.
Here's a pic of mine painted with Duplicolor Cast Coat Iron.
Here's a shot with Duplicolor Cast Coat Aluminum.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-05-2011, 09:08 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I'm pretty sure mine will get powder coated when the motor comes out for detail.... Speaking of detail who's blue motor is that???? Check out those spark plug wire holders..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-05-2011, 10:33 AM   #5
Dunenutt
Newbee
Dunenutt's Avatar
I shot mine with this, right out of the box...
http://www.por15.com/PELUCID/productinfo/PELG/
I dont have many miles on it, but it looks great.
Dunenutt is offline   Reply With Quote
Old 11-05-2011, 12:21 PM   #6
hayhauler71
hayhauler71's Avatar
mine has been on for 5 years and i clean it with simple green. Edelbrock does sell a cleaner to restore the finish
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-05-2011, 05:39 PM   #7
lil hoodlum
lil hoodlum's Avatar
I've used Berrymans carburetor cleaner with good results. Usually just spray over the intake when I'm cleaning the outside of the carb.
Keith
lil hoodlum is offline   Reply With Quote
Old 11-08-2011, 06:41 AM   #8
BigDan3131
BigDan3131's Avatar
There is one option you all are forgetting about and that is having it polished. Polishing it will benefit the motor the most, it causes the heat to radiate from it rather than soaking it up.
BigDan3131 is offline   Reply With Quote
Old 11-12-2011, 12:21 PM   #9
POPO1984
POPO1984's Avatar
I say get it powder coated by Kevin. He does top notch work. That intake sure does look nice and is easy to clean up
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 11-13-2011, 10:36 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Mines sorta stained but some carb cleaner and a rag makes it look good
brake cleaner does even better, but watch the painted areas!
mmmm powdercoat, matt your motor looks great
John
1999 Toyota Tacoma 4x4
