Old 11-18-2011, 11:00 AM   #1
Ben1972swb
355 in a 1972 c10 Swb
Just curious to see if anyone knows the proper operating temperature for my small block? I put dual electric fans in it and I don't currently have a thermostat wired in. The fans just come on at key start. I was thinking of running around 190 degrees. It never gets above 150 now and I'm worried that's not hot enough. Also makes it hard for me to get the heater hot... Thoughts?
Ben1972swb is offline   Reply With Quote
Old 11-18-2011, 11:09 AM   #2
1967wannabe
1967wannabe's Avatar
Re: 355 in a 1972 c10 Swb
Your fans should definitely be thermostatically controlled but shouldn't make the engine run that cold. What temp is your t-stat?
1967wannabe is offline   Reply With Quote
Old 11-18-2011, 12:29 PM   #3
Ben1972swb
I don't have one yet. She's not a daily driver. Only got about 500 miles on the engine since rebuild. The fans are always on. That's why it runs so cold.
Old 11-18-2011, 12:55 PM   #4
1967wannabe
If your running the engine without a thermostat that's why it's so cold, the coolant can't stay in the engine long enough to heat up.
The opposite will occur in the summer time when it's 100 degrees out because the coolant won't stay in the radiator long enough to cool off.
Old 11-18-2011, 05:46 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The stock t-stat should be a 180 degree.
Huck one in there pronto...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
1972, 350, box, short, thermostat
