Old 04-20-2003, 08:38 PM   #1
krue
Designated A-hole!
krue's Avatar
what's this?
When I removed my gauge panel, I found this black wire going nowhere. I am trying to figure out where it goes.
Thanks, Krue
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-20-2003, 09:32 PM   #2
sgtjed
What if?
sgtjed's Avatar
that might go to your shift indicator light or horn button
2002 red extended cab Silverado
2002 Wheatland yellow Suburban
sgtjed is offline   Reply With Quote
Old 04-20-2003, 09:41 PM   #3
Class of 69
Class of 69's Avatar
Do you have an amp gauge? Looks like the wire for power to the amp gauge from the terminal block on the right fender. Did you test light it for power? One wire on the back of the amp gauge should be solid black, and the other black with a white stripe. If it's coming out of the steering column, it's probably the horn power wire, that's solid black also and wouldn't be live, since it's disconnected..
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 04-20-2003, 11:08 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It is not a wire, that is the fiber optic cable. You'll notice it goes up your column underneath in the metal cover, the other end is in the shift pointer.
The end you are looking at should plug into the inst light on the inner side of the speedo, there is a small metal retainer that is supposed to be on it, and the bulb retainer its self has a hole in it that it slides into.
You can glue it if the metal retainer is missing.
Old 04-20-2003, 11:12 PM   #5
Class of 69
Good call longhornmail.... thought it was a funny looking wire...hard to tell what this stuff is by a picture sometimes!
