![]() Join Date: Apr 2000
brake upgrade questions
I have a booster/master cylinder/prop valve out of a 71 3/4 ton 2 wheel drive truck with front disc brakes. Can I put this booster setup into my 3/4 ton 4x4 that I will be adding 71/72 front disc brakes to? Are all these pieces common 2 wheel drive to 4x4?
Bob |
Recovering Truck Driver
I think the master cylinder and booster are the same, the prop. valve might be different, but I'm not real sure.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
any more good comments or advise?
Please help!!
Bob |
Same
They r the same they r different if u go to a drum/drum setup versus the disc /drum
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
