Old 12-27-2011, 09:15 PM   #1
Fangio
Fangio's Avatar
New to carbed engines, need some SBC misfire help
First time messing with a carburated engine and need some help troubleshooting. Its a 64 lwb with a Chevy 350 with turbo 350 trans. Engine always starts on first crank and idles great but while accelerating at anything greater than half throttle the engine sputters and misfires. If I back off the throttle it continues to accelerate without issue. It has an edelbrock performer 600 with electronic ignition. Previous owner said he installed new spark plugs adjusted valves, and set timing. All the vacuum lines look to be in good shape as do the plug wires. I haven't spent much time looking at it yet but my initial thought is timing. Any other ideas or maybe a good plan of attack? Thanks in advance.
Fangio is offline   Reply With Quote
Old 12-27-2011, 09:44 PM   #2
Coley
Coley's Avatar
Smile Re: New to carbed engines, need some SBC misfire help
Putting a timing light on it is job 1......are you familiar with the procedure and set targets?
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 12-27-2011, 09:52 PM   #3
pat565
I have seen this before
The valves are set too tight!
pat565 is offline   Reply With Quote
Old 12-27-2011, 10:16 PM   #4
Fangio
Fangio's Avatar
I am familiar with a timing light and how to use one, just dont have one available at my apartment.
Ill put the valves on the list.
For the time being is there anything else I could check and rule out with a multimeter and basic hand tools?
Old 12-27-2011, 10:25 PM   #5
pat565
Ported vacumn leak.
Old 12-27-2011, 11:30 PM   #6
sapper4
I agree with pat565. It is an advance issue, most likely a ported vacuum leak. You can also check your vacuum pot to make sure it doesn't leak.
sapper4 is offline   Reply With Quote
350, misfire, sbc
