Old 12-30-2011, 08:54 PM   #1
CHEVYFORLIFE
86 k1500 4WD
hey guys, this may be a dumb question but i have a 86 k1500 4WD and i cant figure out what to do with the front hubs for the 4WD lockers...... The caps wont go on my rims... I would post a picture but i have no clue how
CHEVYFORLIFE is offline   Reply With Quote
Old 12-30-2011, 09:43 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 86 k1500 4WD
I'm not sure what you are asking. Are you trying to lock your hubs? Are you trying to put on hub caps?
Pictures: upload to photobucket. copy the image link and paste in your text field.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 12-30-2011, 09:45 PM   #3
Mike C
Mike C's Avatar
Re: 86 k1500 4WD
It sounds like you are trying to put closed center wheel caps on which doesn't work. You need an open center cap that you should be able to get from whoever you got your wheels from. But a picture IS worth a 1000 words...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-30-2011, 11:19 PM   #4
CHEVYFORLIFE
Re: 86 k1500 4WD
can u tell me how to post a pic? i will... can u buy different caps? because it comes off with an allen screw. im not putting on hubcaps, im putting on 20 inch rims and the centercaps for the rims will not fit because of the fourwheeldrive hub.. I dont know if i can buy different centercaps for the rims, if u can shorten the hub, or if there are certain rims i need to buy
