Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-07-2012, 09:54 PM   #1
oldblue72c10
LIGHT' EM UP!!!!!!!!!!
oldblue72c10's Avatar
subs rubbing on seat need help
I have a 1987 silverado single cab with a truck box and 2 10" kicker comps and the seat is moved forward fully. and they rub on the back piece of vinyl that covers the back of the seat, how can i solve this problem, it is actually rubbing some of the foam subwoofer surround off. thanks
BONDO IS YOUR FRIEND WOULD YOU EVER USE YOUR FRIEND
1972 custom 10 longbed
current 360 building a racing 355
oldblue72c10 is offline   Reply With Quote
Old 01-08-2012, 05:29 PM   #2
vegas80step
vegas80step's Avatar
Re: subs rubbing on seat need help
don't have an answer for ya but I have a question.. can you hear the vinyl "slap" against the speaker? I'm starting my audio build and am worried I will have that problem...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 01-08-2012, 10:32 PM   #3
1LowToy
Sounds like you need a narrower box or some real short legs. I'm in the process of buliding a box to fit snug against the back wall so I know where yout at.
1LowToy is offline   Reply With Quote
Old 01-09-2012, 12:05 AM   #4
Chad215
Is there a reason you're not using a grill?
'64 GMC in progress
http://67-72chevytrucks.com/vboard/s...d.php?t=484861
Chad215 is offline   Reply With Quote
Old 01-09-2012, 01:53 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
It's very possible you could even if his doesn't. If you can't build the box to make up this room, grills are your best bet. I had this issue with my S10, so I built the box, and then put another 3/4" piece of MDF around the front so the speakers looked recessed. My speakers don't hit my seats but the excursion isn't that much on them.
I'd put some on before doing anything else...the cheapest and easiest fix hopefully.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-10-2012, 07:53 PM   #6
oldblue72c10
There is no slapping on the seat just that the seat is eating the surrounding of the sub.
Old 01-10-2012, 09:40 PM   #7
76stepsidechevy
I have the same issue and no room to run grilles. My seat has rough carpet on the back of it so thats probably not helping. Im thinking a smaller box with an extra layer of mdf on the front so the subs can be recessed a little bit and not hit the seat so much.
76stepsidechevy is offline   Reply With Quote
Old 01-10-2012, 11:50 PM   #8
oldblue72c10
The only problem is im not a pro at the jig saw haha
Old 01-15-2013, 08:20 PM   #9
MrMilks
MrMilks's Avatar
I drive an 85 single cab with 2 12's behind the seat, its not quite all the way back but the subs don't slap the seat. just get a box made for a single cab. I got mine from hifisoundconnection.com
http://www.hifisoundconnection.com/S...id/0/SFV/30046
Thats the same one I have but mine is for 12's not 10's
MrMilks is offline   Reply With Quote
Old 01-15-2013, 09:12 PM   #10
calvin78612
calvin78612's Avatar
Where can you find grills?
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 01-16-2013, 07:10 PM   #11
king-918
king-918's Avatar
http://www.sonicelectronix.com/searc...&keyword=grill
or make some wood rings that are longer then the excursion of the speaker
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 01-17-2013, 12:08 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
sometimes just a house /bar "pro" sound gear place sells them cheap
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-18-2013, 02:55 PM   #13
_Ogre
_Ogre's Avatar
like king said make a ring to go extend the protection of the speaker
or recess the speaker into the box this would be my choice
if it's a carpeted box this would be easy to do, a little more challenging if it's painted
not a good pic but i recessed my ring when i made the box
if you have your seat all the way forward the box is wrong for your truck
while i made mine to fit my 58 this would be an easy box to adapt to any truck
i'm tall and designed this box to have the seat against the back window
shop air compressor timer
