Old 01-11-2012, 04:34 PM   #1
Toshab
Toshab's Avatar
Advice Needed: Rebuilding a 327
I started a thread earlier to ask for help in my Chevy '67 C10 rebuild. To make a long story short, the man I bought it from told me I was buying a 283 in her, but thanks to some help from this forum, I found it is actually a 327 .
You can watch the story unfold here if you want to: http://67-72chevytrucks.com/vboard/s...d.php?t=500888
The motor knocks pretty hard, especially on start up and at high rpms.
I'm kind of wet behind the ears when it comes to motors. I have some experience, but probably not near as much as all of yall do. I want to mildly modify this 327. Not something that is going to cost me thousands and thousands, but I have a little bit put back that would allow me to have some fun with it.
What do yall recommend as far as:
Carburetor
Intake manifold
Camshaft
Heads
And anything else I don't know to ask about
The casting number is 3892657
The engine ID number is VIOIOMA
(I'm really not sure what you do with these, but somebody in the last thread said they help )
I know I have to make sure I don't have a cam that is too big for my heads and stuff like that, but I don't know exactly what to compare when looking at that. Any explanations would be very educational for me.
I plan on posting pictures as a progress through everything. Here's a picture of my beauty, and the before pictures of the engine.
Toshab is offline   Reply With Quote
Old 01-11-2012, 06:51 PM   #2
BigSwid79
BigSwid79's Avatar
Re: Advice Needed: Rebuilding a 327
I'd be careful with an engine that is knocking... what type of noise are you getting from it? With a knock instead of going all top end parts, I'd look into what in the bottom end is causing the knock and fixing it, 327's are great engines, they spin all sorts of rpms thats why I like em' :P
BigSwid79 is offline   Reply With Quote
Old 01-12-2012, 12:08 AM   #3
Captainfab
60-66 Nut
Well according to what I've found, the MA code shows it to be a 210hp 327 from a '67 Camaro. That will have small valve (1.74 intake, 1.5 exhaust) heads. I would definitely consider a better set of heads, such as the Vortec heads. And yes, if it is knocking, the bottom end likely needs rebuilt as well.
A 600 cfm carb will be sufficient. For an intake manifold, a Edelbrock Performer EPS or a Performer RPM will be a good match. A camshaft of a 262-268 version would be good
Old 01-12-2012, 11:12 AM   #4
Toshab
Toshab's Avatar
I took it to a mechanic who diagnosed the knock as a piston knock.
I plan on doing a complete rebuild.
Is there a size I need to be looking for on the Vortec heads. And about how much does those normally run?
Old 01-12-2012, 04:22 PM   #5
BigDan3131
BigDan3131's Avatar
There goes your not wanting to spend $$$ on it huh?
BigDan3131 is offline   Reply With Quote
Old 01-13-2012, 01:39 AM   #6
Captainfab
60-66 Nut
You will want the L31 Vortec 350 heads used from 1996 thru 2002. You can buy brand new ones, or you can find a good used set and have them rebuilt. A lot of guys will say that having a used set rebuilt, is close to as much as buying a new set. But in my area, I have found that the cost of a quality rebuild on a set of heads is a good bit less. So I would recommend checking prices in your area.
Old 02-13-2012, 06:08 PM   #7
Toshab
Toshab's Avatar
Since I'm going to have to do a complete rebuild, I've decided I can't afford the vortec heads. My dad has a set of TBI heads (76cc) that he will sell me for real cheap that have already been worked on to help defray some cost.
Now I'm having trouble knowing what kind of cam to get.
Carburetor: Holley 4160 600 cfm
Intake Manifold: Edelbrock 7501
Heads: TBI 76cc
I'm not looking for anything too much. I'll take captainfab's advice and go with the 262-268 range. I was looking on compcams website and on summit racing and before I knew it I was lost in an ocean of camshafts and I'm just not real sure how to swim in that kind of water.
Any advice guys?
Old 02-13-2012, 10:09 PM   #8
BigDan3131
BigDan3131's Avatar
XE256H from Comp the peak HP is 273@4500 rpm and peak torque is 357@3500 rpm. These figures are based on the carb/manifold choice stock type heads with 1.94/1.5 valves, stock exhaust with mufflers and 9:1 compression. Anything bigger and the power fell off.
Old 02-13-2012, 10:41 PM   #9
Toshab
Toshab's Avatar
I have headers and Flowmaster exhaust. Does that change anything?
Old 02-14-2012, 05:01 AM   #10
BigDan3131
BigDan3131's Avatar
The XE 262H, HP is 302@5000 rpm torque is 375@3500 and it has more average hp and torque than the other one. Also its idle is more noticeable because the duration is about 10 degrees higher. So it will have a nice sound and run well.
Old 02-14-2012, 01:13 PM   #11
Toshab
Toshab's Avatar
I love this forum.
Old 02-16-2012, 09:09 PM   #12
Toshab
Toshab's Avatar
Anybody know of a high quality gasket to put on a set of headers to keep the leaks from happening?
Old 02-24-2012, 04:58 PM   #13
Toshab
Toshab's Avatar
Well....the heads dad was going to sell me for cheap turned out to be junk. So I'm looking at the L31 Vortec heads mentioned earlier in the thread. The guy at the machine shop said I could go for a set of Procomp Aluminum heads for about the same price. Which one is better?
My hopefully-low-dollar rebuild has suceeded at turning me into professional beggar, and my wife is growing weary of being a cheerful giver.
1967 Chevy C10 350
1967 Chrysler Newport Custom 383
1985 GMC Sierra Classic - Now a parts warehouse
Old 02-24-2012, 05:41 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The Pro-crap heads are... well... crap.
No engine rebuild is cheap. If you cut corners and use cheap parts... you'll be doing it all over again later on. Then it gets expensive.
You can get the Summit Vortec heads for a good deal. Also with Vortec heads you have to use self aligning rocker arms as well.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-24-2012, 11:48 PM   #15
Captainfab
60-66 Nut
Old 02-25-2012, 01:00 PM   #16
Toshab
Toshab's Avatar
I'm beginning to see the truth in this.
Looking on summit racing, I found the vortec heads. The application is for a 350, but since the 327 is the same block, they should also work on a 327, right?
1967 Chevy C10 350
Old 02-26-2012, 12:33 AM   #17
Captainfab
60-66 Nut
Yes the Vortec heads will bolt onto a 327 just fine....they're both small blocks.
Old 02-26-2012, 06:21 PM   #18
Dustytrix
But if you get vortec heads, I got some love them for the price you can't beat them. But make sure the intake will work with vortec heads. The vortec have 8 bolts to the intake, regular heads have 12 and they are on a different pitch.
Dustytrix is offline   Reply With Quote
Old 02-27-2012, 11:54 AM   #19
GASoline71
GASoline71's Avatar
Good point Dusty. To use Vortec heads you have to use a Vortec compatible intake manifold. Edelbrock makes 'em. Pretty slick...
Gary
1967 c10, 327, overhaul
