Old 01-11-2012, 05:32 PM   #1
ImAnIdiot
ImAnIdiot's Avatar
Transmission Swap??
I have a four speed manual SM465 on a small block 305. I want to get a fifth gear if possible. Are there any 5 speed manual transmissions that will bolt to a small block 305?
1972 K10 4wd
ImAnIdiot is offline   Reply With Quote
Old 01-11-2012, 09:58 PM   #2
rcbildr
rcbildr's Avatar
Re: Transmission Swap??
Either go with the NV-4500 or the lighter duty NV-3500 will work.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 01-12-2012, 11:33 AM   #3
ImAnIdiot
ImAnIdiot's Avatar
Thanks for the info. I will look into them.
Old 01-13-2012, 04:39 AM   #4
rcbildr
rcbildr's Avatar
Been thinking a little more about this today. For the price of either of those transmissions and getting them in your truck, you could get a gear vendors overdrive and set that up too.
My Projects:
1978 Camaro Z28
sm465, transmission swap
