Old 01-15-2012, 03:03 PM   #1
oldblue70
oil pan
Does anyone know if you can remove the oil pan on a small block with it still in the truck?
Trying not to pull the motor just to put a new oil pan on.
I have a 70 c10 2wd.
oldblue70 is offline   Reply With Quote
Old 01-15-2012, 09:00 PM   #2
litew8
litew8's Avatar
Re: oil pan
You may need to lift the engine/tranny up with a cherry picker in order for the pan to slide out.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 01-15-2012, 09:52 PM   #3
bollybib
bollybib's Avatar
Re: oil pan
Disconnect the motor mounts, jack the engine up so you can get a piece of 2x4 in the space between the engine and frame mount.
If you jack against the oil pan, use a piece of wood to spread the load so you don't bend the pan.
http://67-72chevytrucks.com/vboard/s...&postcount=195
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 01-16-2012, 07:12 AM   #4
oldblue70
Re: oil pan
Thanks for the answers, at least I can have a ideal of what to expect when I start to change the oil pan and gasket. Thanks
Old 01-16-2012, 11:04 AM   #5
geezer#99
geezer#99's Avatar
Re: oil pan
When you jack up the motor watch for any other things that can get stretched like the rad hoses or power steering hoses or rad shroud. I unbolted my rad when I did mine and let it slide up and loosened my PS pump so the hoses could move further.
geezer#99 is online now   Reply With Quote
Old 01-16-2012, 11:18 AM   #6
bollybib
bollybib's Avatar
Re: oil pan
Like geezer#99 says, too.
- Jim -
Old 01-16-2012, 11:40 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Re: oil pan
Also check the distributor especially if it's an HEI and very close to the firewall. I had to remove mine. If you have a shroud make sure the fan will clear it. Don't forget the fuel pump hose and the exhaust pipe.
Basically just use caution and make sure everything clears.
68gmsee is offline   Reply With Quote
motor, oil, remove
