Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-15-2012, 05:25 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
Parting out 1973 Chevrolet Cheyenne C20 3/4 ton
1973 Chevrolet Cheyenne C20 3/4 ton all or parts have title in hand
nice dent free front bumper, good chrome w/ brackets sold
radiator support sold
big block fan shroud sold
Big Block 4 core radiator sold
fenders, couple of dents in each sold
sliding rear window plastic latch is broken $50
white sun visors sold
inside pillar/ headliner trim $20 + shipping
door panels, arm rests and storage pockets $40 + shipping
14 bolt full floater, not sure of ratio or if posi or not sold
crack free windshield sold
Driver side door needs patch on lower outer corner sold
bed floor is rusty, but bed is useable sold
TH400 trans SOLD
nice black dash pad no cracks SOLD
non tilt steering column with key and wheel SOLD
Factory AM FM radio not sure if it works or not SOLD
grille sold
headlight rings sold
grill trim sold
engine not for sale
WIDESIDE72 is offline   Reply With Quote
Old 01-15-2012, 05:26 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: Parting out 1973 Chevrolet Cheyenne C20 3/4 ton
Clear title whole truck minus engine and parts listed as already sold for $400
Old 02-14-2012, 02:00 AM   #3
redsled87
redsled87's Avatar
Do you still have the fan shroud? If so, what is the diameter of the fan opening.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 02-16-2012, 12:14 AM   #4
cahurst2001
cahurst2001's Avatar
What condition are the door panels? I'm also interested in the front sway bar if it has one.
1973 C10 350 700R4
cahurst2001 is offline   Reply With Quote
Old 02-16-2012, 12:16 AM   #5
cahurst2001
Forgot to ask about the door molding. Decent condition?
1973 C10 350 700R4
Old 02-16-2012, 12:54 AM   #6
ozark
Do you have the trans crossmember?
ozark is offline   Reply With Quote
Old 02-16-2012, 01:09 AM   #7
cahurst2001
Correction : weatherstripping/seals
1973 C10 350 700R4
Old 02-16-2012, 11:52 PM   #8
Rogue_Sentinel
Rogue_Sentinel's Avatar
Pm
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final."
Hunter S THompson
Rogue_Sentinel is offline   Reply With Quote
Old 02-17-2012, 12:08 AM   #9
WIDESIDE72
WIDESIDE72's Avatar
It does have te TH400 cross member. IT would be a while before I can pull it.$40 + shipping since it is a PITA to pull out.
Steve
Old 02-17-2012, 12:09 AM   #10
WIDESIDE72
WIDESIDE72's Avatar
I will check the door panels. I am going to be using the sway bar on another truck.
Old 02-17-2012, 12:10 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
I will check tomorrow
Old 02-17-2012, 12:10 AM   #12
WIDESIDE72
WIDESIDE72's Avatar
I do still have it. Iwill check it tomorrow.
Old 02-17-2012, 10:00 PM   #13
ozark
Steve
I'm interested in the cross member. Just to be sure this is the one that looks the same on both sides, not the goofy one that the crossmember goes under the driverside frame rail and the pass side sits inside the frame rail. Let me know when you get it out. thanks
Old 02-17-2012, 11:11 PM   #14
qksilver
any pix of the bumper? shipping to 28387?
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 02-22-2012, 01:39 AM   #15
redsled87
redsled87's Avatar
I thought that I would let you know, the set up won't work for what I am doing. I went electric fan route. Thanks
60' 1.49
1/4 10.93
MPH 120
Old 02-27-2012, 07:27 PM   #16
WIDESIDE72
WIDESIDE72's Avatar
The shroud opening appears to be around 24". There are no cracks or breaks $40+ shipping.
Old 02-27-2012, 07:28 PM   #17
WIDESIDE72
WIDESIDE72's Avatar
Thanks,
Steve
No shipping on bumper. Too expensive and too much hassle.
Old 02-27-2012, 07:30 PM   #18
WIDESIDE72
WIDESIDE72's Avatar
Seals are toast
Old 02-27-2012, 07:33 PM   #19
WIDESIDE72
WIDESIDE72's Avatar
Plastic is in good shape, not chalky, the wood grain is worn off driver side where previous owner rested his asrm. The passenger side is better, elastic is gone in both storage pockets, both arm rest pads are so so. $50 + shipping for pair
Old 02-27-2012, 07:41 PM   #20
WIDESIDE72
WIDESIDE72's Avatar
The seat belts appear to be in decent shape. The plastic retractor covers are pretty well shot though. One release buckle on belt is missing the "GM" tag on the release button. Some rust on back of buckles. Woolite on the belt webbings and some WD40 and a scotchbrite pad on the chrome buckleswould do wonders for these. (These are lap belts only, not shoulder belts.) $40+ shipping for all belts mainly due to the fact that these are going to be a PITA to get out. You can have them for $20 if you pull them.
Old 02-27-2012, 09:11 PM   #21
trout
I want the door panels if he passe
Edited by staff
trout is offline   Reply With Quote
Old 02-27-2012, 10:50 PM   #22
azjaeger
azjaeger's Avatar
How are the Cheyenne 20 emblems on the front fenders?
azjaeger is offline   Reply With Quote
Old 02-27-2012, 11:01 PM   #23
MilkyJoe
MilkyJoe's Avatar
does it have the Cab Band?
Thanks,
Chris
MilkyJoe is offline   Reply With Quote
Old 02-28-2012, 12:18 AM   #24
ozark
still interested in the trans crossmember.
Old 02-28-2012, 12:03 PM   #25
dieselmec1993
do u still have this if u do i would like the frame and the front with arm suspention if u still have it or just frame will work
1977 k20 frame with 85 cab and hopefully 6.5 diesel.
1981 c20 long box 250 3 on the tree daily driver.
1982 k25 with 86 cab tired 350 4speed trans 37in military tires.(project Frankenstein). 8.
1984 c30 crew cab dually 6.2diesel next project
only 18 and finshed 5 projects started when i was
dieselmec1993 is offline   Reply With Quote
