Old 01-25-2012, 01:29 AM   #1
ApacheWillard
ApacheWillard's Avatar
Wheel and tire question
Hoping you guys can make this pretty painless...
My 1960 swb has a 63 front end under it, stock rear end, 6 lug all around w no disc brakes. I'm lowering it 3/5 next week, and then it will be time for a wheel and tire change as the 295 series that are on it now would rub. I'm wanting to go with a smoothie style wheel, either all blacked out or w chrome trim and baby moons with some white walls. Places like jegs and summit have the wheels priced pretty decent, I'm just unsure as to what rear spacing to have on the wheels say on a 15x7 or 15x8? Also, what tire sizes do you think would go best with these wheel sizes? These wheels should have no problem working right, as long as I choose the right backspacing and get them in 6x5? Thanks again, and any pictures relating to the topic would be greatly appreciated!
ApacheWillard is offline   Reply With Quote
Old 01-25-2012, 01:47 AM   #2
forestb
forestb's Avatar
Re: Wheel and tire question
When I ordered a set of 15X7's Rally wheels they had a 4 inch backspace and that fit great and I had a 4.5/4 drop. The tires I used were 275/60R15. But that was with a 4 inch drop in the rear not a 5.
forestb is offline   Reply With Quote
Old 01-26-2012, 10:40 AM   #3
ApacheWillard
Anybody else? What size tires you running on your lowered trucks?!
Old 01-26-2012, 07:22 PM   #4
Slow Build
Slow Build's Avatar
I'm running 275/60/15's on 15x8 rallies. No rubbing. This is with the stock drums up front. If you are lowering with spindles and disc brakes it most likely will move your wheels out 3/4" per side so you need to take that into concideration. A 295 tire is pretty wide for a 7" wide wheel also.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-26-2012, 07:44 PM   #5
gimmy 64
i am running 15x8 corvette style wheels with 245/60's front and 275/60's on the rear
gimmy 64 is offline   Reply With Quote
Old 01-27-2012, 01:44 PM   #6
ApacheWillard
Thanks for the replies people! Anybody ordered anything from wheel vintiques before?
Old 01-27-2012, 05:56 PM   #7
forestb
forestb's Avatar
Yes. There parts are good there customer service is horrible. Also they do not let you return anything unless it is damaged. I tried to return something that was still in the box and they wouldn't let me. And make sure that the wheels are not bent before you mount the tires. I heard about a guy finding out after he had the tire mounted that the wheel was bent and they would not let him return them.
1960, apache, smoothie, tires, wheels
