View Poll Results: Wide wheels or Dually's
Big Wide rears 4 44.44%
Big tall Dually rears 5 55.56%
Voters: 9. You may not vote on this poll
Old 01-31-2012, 07:02 AM   #1
72 DIRTY RAT
72 DIRTY RAT's Avatar
Which way should I go, Dually or wide wheels
HI guys,
I want your opinions/survey on what to do.
Next year or so I will start transforming my 72 suburban. Basically its going to be hot rodded.
I'm not sure what I want to do with the wheels, and these are the options I want to do.
1. big fat wheels/tires, probably 18 x 15 wheels rear, 20 x 10 (maybe wider?) front. Obviously I will have to tub it and have tires as close to the chassis as possible.
2. Go the Dually truck looking way, but with big aluminum or chrome 191/2 inch 8 lug wheels or bigger 10 lug wheels with adapters as in the pictures below.
Does anybody know if you can fit duallys under the back guards without the later model flares? I have seen it done obviously I would have to tub the interior.
This would be the 10 lugger (too big??)
without flares, how would this be done?
*1972 454ci Burb, C20 3/4T, T700, 2WD
*1969 540ci Vette, 540ci Aluminum BB,755 BHP & 734 LbFt torque, No NOS, No Forced induction! Just BIG CUBES
72 DIRTY RAT is offline   Reply With Quote
Old 02-05-2012, 12:13 AM   #2
Average Joe
Average Joe's Avatar
Re: Which way should I go, Dually or wide wheels
I like the 10 lug look. However I think you'd have to have outer fenders to make it look right JMO. If that's not feasable I say tub it and go with a wide single.
Average Joe is offline   Reply With Quote
Old 02-06-2012, 01:39 AM   #3
71gmcburb
71gmcburb's Avatar
when you do your rear conversion get the rear axle from a cab and cassis drw truck, they are narrower then the regular rear axle and will let you set your wheels compleatly inboard with no flares needed check out this link it shows the fitment
http://67-72chevytrucks.com/vboard/s....php?p=5165592
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 02-07-2012, 06:21 AM   #4
Cumminpwr11
Southern Nevada Coal Roller
Dually Suburbans are bad AZZ!!!! I want to go that route myself.
I'm looking for some step side fenders to dually out the back end with.
Keep us posted on the progress.
Chris
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline   Reply With Quote
Old 02-11-2012, 04:09 AM   #5
72 DIRTY RAT
I think I am leaning toward Duallies! I havent seen anyone do it here in Australia yet, I'm thinking 22 1/2 inch wheels now. Mine Suby wont be lowered to much. There is a good variety out there and relatively cheap compared to 20 x 15 wide rears with tires! I might also make some custom rear fenders? to suit the lines of the truck rather than using later model fenders.
Old 02-14-2012, 03:32 AM   #6
72 DIRTY RAT
Inboard duallies look good but now I dont know if I should go 'inboard' or 'out board'? I found the wheels (22in) and tires I want, the tires will be dual 275 or 295/45- 22s, so I dont think they will fit inboard?? thats nearly 2ft across!!
Old 02-22-2012, 09:35 PM   #7
502ms
502ms's Avatar
I love that !
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-22-2012, 09:39 PM   #8
502ms
502ms's Avatar
Need to add that I want them wide...so, as pictured would be great
Best Regards,
Leon M.
