01-31-2012, 10:17 PM | #1 |
slide in receiver hitch help?
Ive done 0 research on this but im looking to put a hitch on my 66 gmc suburban. I have never delt with buying one before or anything and dont know all the ins and outs. All the trucks I have owned already had one when I got them. Are they kinda universal to frame widths and you simply drill holes and bolt it up? Thanks guys.
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
01-31-2012, 10:44 PM | #2 |
Re: slide in receiver hitch help?
They are not universal. Different years/models have different frame widths. Any auto parts store should be able to order one for you that is built for your truck. I ordered the hitch for my 67 C30 from Advance and it fit great.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-31-2012, 10:47 PM | #3 |
Very cool. Ill have to stop in and order one. I was doing some looking online and haven't seen alot yet.
01-31-2012, 10:49 PM | #4 |
I did see some adjustible width one at Walmart but that doesnt seem all that strong.
01-31-2012, 10:56 PM | #5 |
So I look at the top of the message board page and noticed that etrailer has an ad up there. And yeah they have them. of course not listed for a burb but for a puckup. Why would it matter if its a long or short bed? As I understand my burb qould be considered a shortbed right?
http://www.etrailer.com/Trailer-Hitc...cleid=19661293 Posted via Mobile Device
01-31-2012, 11:26 PM | #6 |
the frames are a little bit different at the back. suburbans have an extension on them.
ron |
01-31-2012, 11:33 PM | #7 |
Order from a local place. That way if it isn't right you can return it. Sometimes it will save significantly on shipping too.
01-31-2012, 11:36 PM | #8 | |
02-01-2012, 12:06 AM | #9 |
I tow a boat so I've installed a hitch on all of my vehicles that didn't come with one. I have a local muffler shop that also sells hitches. They are top quality and are able to install them in under 30 minutes. You might try one of those shops local to you.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
02-01-2012, 12:10 AM | #10 | |
02-01-2012, 12:29 AM | #11 |
Just here to tinker
I ordered a universal motorhome hitch from hidden-hitch for my old '60. Here are the pics. A hidden hitch probably won't work on your suburban because it would have to go through the bumper, but you can get a universal drop-hitch I'm sure.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
02-01-2012, 12:36 AM | #12 |
been around before: http://67-72chevytrucks.com/vboard/s...d.php?t=437750 a Suburban application in post #25
02-01-2012, 12:39 AM | #13 |
Yeah, if I had a bumper mounted license plate id go that way for sure.
02-01-2012, 12:45 AM | #14 | |
02-12-2012, 10:17 PM | #15 |
Got the hitch on today!
Posted via Mobile Device Posted via Mobile Device
02-13-2012, 01:43 PM | #16 |
So what option did you go with? Did you order a universal fit or custom built? I have a 66 Suburban that will need this some day.
02-13-2012, 02:01 PM | #17 |
I went with the Reese SUV universal unit. Went in easy.
02-13-2012, 02:51 PM | #18 |
Never Ending Projects
Got any pics from underneith of the hitch?
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-13-2012, 02:53 PM | #19 |
Ill take some.
02-17-2012, 03:46 PM | #20 |
02-17-2012, 04:12 PM | #21 |
Looks good! Glad it went fairly easy. You can always rely on someone here to have the answer. If not, you asked the wrong question. : )
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
02-17-2012, 04:24 PM | #22 |
Thats true. Im glad I asked.
02-17-2012, 11:54 PM | #23 |
I have never had alot of luck with those wire splicer connections. Seems like about once a year or so I have to kinda wiggle or even open them up cuz something stops working. So this time I soldered all the connections for the trailer plug. I have no need for the larger 7 blade plug but I installed the plug with both for future use. When I get some time ill wire in the hot lead for the plug. Im thinking im going to end up with an amp for the stereo in the rear of the burb so ill probably end up running all the wiring back then. Brakes,amps,RCA's,remote rear door lock, ect....
02-18-2012, 11:45 PM | #24 |
1966 Crew Cab & 4X4 Fanatic
Doug,
Is the boat behind your Burb what you are going to pull? I love it when 60-66 Trucks, Suburbans and Panels are used to tow boats, camping trailers, toy haulers, etc. 20 years ago I was at an Arizona lake and saw a 1966 Chevy 4x4 Panel pulling a bad ass matching jet boat, they were both painted yellow and the Panel had a mural painted on its sides and the boat had the same mural painted on its bow. I sure wish I had some pictures of that combo as this is burned into my mind after all these years. |
02-19-2012, 12:04 AM | #25 | |
