Old 02-02-2012, 12:50 AM   #1
gramps77
odd dash lighting issue
Does the dash wiring somehow get power via the same harness as the radio? About a week ago I pulled the old AM radio and didnt drive it or start it since then. Now, I have no dash lights and the temp gauge and alt gauge dont work. Nor does the fuel gauge. Im hoping its simply because I dont have the radio hooked up. Also, the turn signal indicators in the dash stay on now but will flash when I use the signal. I dont have a diagram to go through and verify, thanks for any help
gramps77 is offline   Reply With Quote
Old 02-02-2012, 09:00 AM   #2
donut
donut's Avatar
Re: odd dash lighting issue
Make sure the harness is still plugged into the bezel (left side of speedo). I pulled my radio to get to the heater controls and jostled mine loose. Lost most of my dash lights and gauges.
Beyond that, I got nothin'.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-02-2012, 11:54 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
they do all run from one ground (less then a foot from the cluster plug)
and the grey for the radio/heater light is run the same as the cluster dimmer
if you look back threw my 78 jimmy it will show you more
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-02-2012, 12:27 PM   #4
silvereagle07
silvereagle07's Avatar
It does sound like a ground issue.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-02-2012, 10:52 PM   #5
gramps77
thanks for the help fellas, got a better idea now
Old 02-05-2012, 06:52 PM   #6
gramps77
Winner Winner Chicken Dinner
Thanks motornut and silver eagle
You guys were right, one lone wire just behind the left A/C vent the ground had simply separated from the terminal that bolts to the E-brake bracket. Turn lights on, dash stop working, touch wire to terminal it jumps back to life.
