Old 02-08-2012, 03:50 AM   #1
tll74
"Junkyard Dog"
tll74's Avatar
Sub AC question
I have a 70 Sub that appears to have a factory or dealer add on AC system. Ok...this truck only has the rear AC that goes all the way to the front of the truck down the center of the ceiling. The main heater system is a standard non AC set up. Now the compressor and condenser set up is all factory components. The whole system appears to be GM. The spid doesn't mention AC so it's my thought it is a dealer add on. Any body seen or have on of these systems? I'm also considering on parting this truck out and curious what it may be worth. This is not a for sale add just looking for info and ideas of value. Thanks
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 02-08-2012, 04:41 PM   #2
tll74
"Junkyard Dog"
tll74's Avatar
Re: Sub AC question
Ttt
Old 02-08-2012, 05:18 PM   #3
vectorit
What?
vectorit's Avatar
Re: Sub AC question
The A/C sounds like a dealer add on.
Mine had it, and I took it all out since it was too troublesome to maintain.
In my set up, it had a giant square shaped compressor made by York and a condenser unit that would drip a huge lake of water into the truck
Took it all out and trashed it.
As for worth of parts, it all depends on condition.
The entire front clip is PU and Blazer compatible, so your market is much bigger. from the front doors back its burb only, and if the big stuff like doors and rear doors are rust free you can get a good price for them. Especially the rear doors.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-09-2012, 04:38 AM   #4
1leglance
Re: Sub AC question
I have that setup on mine and pulled it off the roof and I am working on putting it under the second row seats and building a custom console to blow the air up to everyone.
No idea if it will work or not
1leglance is offline   Reply With Quote
