Old 02-09-2012, 09:40 AM   #1
bodyman922
bodyman922's Avatar
Question LS swap questions
I have an 87 silverado, 350 throttle body injected with 4 wheel drive I am looking to upgrade the engine in. The truck is a minnesota truck with usual rust and is used for the 4 wheel drive and the towing capabilities. It runs good but uses a quart of oil every 400 miles. I was told the motor has never been apart and has over 200,000 miles on it so I would like to upgrade to an LS engine if it is cost effective. I am thinking a 5.3 truck engine from a 1999 and up truck. I am not looking for more power only a truck that is more efficient. It would also help to keep another square alive!
I would like to know from those who have performed the swap if your fuel milage has increased or has stayed the same? Also would like to know if it is possible to keep the stock throttle body injection?
Any info you may have is appreciated. Thanks
bodyman922 is offline   Reply With Quote
Old 02-09-2012, 10:33 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: LS swap questions
To keep the stock TBI setup you'll probably have to buy an aftermarket carbureted LS intake and use a carb-TBI adapter. If you're keeping the TBI setup and not using the EFI, I'm not sure how much of a gain you'll see. I would bet money it would be worth a few MPG over a worn out small block with over 200,000 miles on it, though!
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 02-09-2012, 12:52 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
on a 4by I doubt your mileage would improve much, firstly because the drivetrain is staying the same, if you put the 4 speed in, then it might increase on highway. you would want to use what is on the motor, I would holler at John with PCI on a harness that would work well with your existing body harness. also dirty dingo would have the motor plates/mounts you would need. Good luck
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-09-2012, 02:44 PM   #4
Gregs71
You didn't say if the truck has overdrive or not and whether its an auto or stick.
What you want to do is probably possible ( 5.3 TBI with stock tranny / TC), the least efficient, but the easiest to do.
The next efficient combo is the full fuel injected (means swapping wiring harness and computer) with stock tranny / TC.
If you have a 3 speed tranny, the most efficient combo is the 5.3 fuel injected ( not TBI) with overdrive. If the 4 speed is a modern 4 speed (4l60/4l80) then you have the added difficulty of mating it to the transfer case. If your running the 700r4, then your mating the 5.3 to the 700r4. If its a manual then and you add overdrive, your back to having difficulties mating a new OD manual tranny to your 5.3 and stock TC.
I have been kicking a round a similar idea. I'd like to hook up a 6.0 to my th400, more for reliability then efficiency though.
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
engine swap, ls engine, throttle body injection
