Old 02-13-2012, 02:22 PM   #1
csa daddy
csa daddy's Avatar
Oil pan gasket change
I have a 2001 suburban 4x4 with a 5.3 vortech an the oil pan is leaking is this a common issue to leak near the oil filter housing. Also what is the easiest way to change the pan gasket.
csa daddy is offline   Reply With Quote
Old 02-13-2012, 05:45 PM   #2
clinebarger
Re: Oil pan gasket change
Ive seen them leak there, Not really common though, You made sure its not the little cover above the oil filter?
Drop the front diff down & the pan comes right out. Put a new O-ring on the oil pick-up tube while your in there.
clinebarger is offline   Reply With Quote
Old 02-13-2012, 06:27 PM   #3
csa daddy
csa daddy's Avatar
I was hopeing not to have to drop front dif if possible
Old 02-13-2012, 06:35 PM   #4
clinebarger
It has to be dropped down, Leave the drive axles & drive shaft in. Its not that hard.
Old 02-13-2012, 10:28 PM   #5
csa daddy
csa daddy's Avatar
Thanks I guess I will find out exactly how difficult it is
