![]() Join Date: Nov 2010
Grant steering wheel install info
Do I use the long spring or the short one? Read the directions and it says the long one. Just seems like short one would work better.?!
Posted via Mobile Device |
Re: Grant steering wheel install info
bump
![]() Join Date: Feb 2001
Maybe these LINKS might help
http://67-72chevytrucks.com/vboard/s...d.php?t=485875 http://67-72chevytrucks.com/vboard/s...ghlight=signal http://67-72chevytrucks.com/vboard/s...ghlight=signal http://67-72chevytrucks.com/vboard/s...d.php?t=468717
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Thank you
Saw one of those links before Was looking for what spring to use in the grant hub itself not the column spring. I'm just gonna try em both in the morning and see what works best. |
Ok still need help.
Got everything all hooked up and new wheel on and the damn horn wont stop blowing. Stripped it down piece by piece and it didn't stop till I pulled the Grant hub back off with a puller. So what now? I'm sure it's something simple I'm missing I just don't know what. Help! |
Ok....figured it out and it works. Horn blows and stops blowing when I want it too.
So I have another question. After all of my thread searches on this site and others I found that this is kind of a common problem. So, I've decided to document it on this site step by step, pic by pic, removal of old wheel to install of new wheel so that it might benefit someone else with same problem. My question is should I start a new thread or just run it in this one? Feel I owe something to the forum for all it and its member have done for me. Let me know. Thanks |
Anyone?
do it, im fixing to put a grant on my truck soon and id like instructions. start a new thread or this one. dont matter to me.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
First off the only reason I am changing the wheel is for comfort. Just like the smaller wheel with thicker grip. <--Don't go thinking weird on me. My horn hasn't worked since previous owner and figured out why. Here are the steps that I took to remove my old wheel and install a Grant #457 (with a "signature series" horn button) and a Grant #3163 installation kit. Hope this might make some things easier for ya if you never done it before.
Pic 1: old wheel Pic 2: remove horn button Pic 3: retaining screws and column nut |
Pic 4: remove screws
Pic 5: remove horn button bushing Pic 6: remove horn button cup |
Pic 7: remove metal contact ring (curved piece and should be installed with the higher center towards driver
Pic 8: remove column nut Pic 9: use steering wheel puller and remove wheel to expose turn signal canceling cam |
Pic 10: remove canceling cam
Pic 11: new Grant contact wire Pic 12: seperate Grant wire and remove middle plastic spacer. you don't need this spacer. remove long spring and reuse stock small spring. |
#13 |
Pic 13: Grant contact wire seperated
Pic 14: seperate stock canceling cam from horn contact kit Pic 15: this is where i got screwed up. note the budweiser cardboard in the middle. very custom! i had to use this to keep the horn from blowing nonstop. if you don't use this as soon as you push the Grant hub (top) with canceling cam (bottom) onto the column shaft the horn will blow. this worked best for me. |
#14 |
Pic 16: install Grant hub with canceling cam onto column shaft
Pic 17: install small (stock) spring Pic 18: this gets frustrating...install Grant wire parts starting with brass plunger |
#15 |
Pic 19: install rest of Grant wire assembly and use tape to hold in place. i used painters masking tape because it was close and stuck good.
Pic 20: install hub cover and put column nut on to hold in place. Pic 21: this is where it will probably get different for different styles of wheels. my new wheel uses this mounting bracket to mount the column to wheel instead of directly to hub cover. second installed wire is for back of "signature series" horn buttons only. column wire goes to center of the back of horn button and second wire on mounting bracket goes to outboard of horn button. |
#16 |
Pic 22: new wheel installed and blows like a champ. still like the looks of my old wheel but this one feels better and i feel will drive better for me.
Pic 23: basic Grant instructions Pic 24: back of Grant instructions. do everything this says except for using the long spring. there is no need for the long spring the stock small spring does the job perfectly. |
#17 |
#18 |
I for one, thank you RRR! After fudging the end of the shaft with a makeshift puller 3weeks ago, getting nowhere with the threads last weekend, and ordering a thread fixing tool, I got it all together today just to have the horn do its thing whenever it wanted. I'm no pro at fixing stuff so guys like you really save guys like me
![]() Now I see light at the end of the tunnel...or is that the train? Posted via Mobile Device
1970 K20 Custom 427/TH400/PS/PB and a dash of badass! ![]() I was made in America, my truck was too...4 years before me. |
#19 |
Glad I could help!!!
#20 |
Ha! Got her done!! All hail the Budweiser gasket
![]() Posted via Mobile Device BTW- your gauges look awesome RRR!
1970 K20 Custom 427/TH400/PS/PB and a dash of badass! ![]() I was made in America, my truck was too...4 years before me. Last edited by KY Colonel; 03-11-2012 at 11:44 PM. Reason: Forgot to add |
#21 |
Great to hear that it all works!
#22 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Subscribed. Thanks for posting.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#23 |
![]() Join Date: Feb 2007
Excellent! Thank you so much. I've been scratching my head for a few years on this now. Much appreciated.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#24 |
Thanks for going through the trouble of posting instructions RRR18 but one thing I will suggest to add to your instructions:
Step one - disconnect battery Last step - reconnect battery and test
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#25 |
Ya. I left that out on accident.
