Old 02-17-2012, 04:30 PM   #1
Cheng
Junior Member
'85 One Ton SRW Diesel
This project began late last year when I purchased this truck:
1985 K30 Scottsdale SRW
- 6.2L Diesel Engine
- SM465 Transmission
- NP205 Transfer Case
- Dual Fuel Tanks
- Air Conditioning
- 4.10 Axle Ratios
- G80 Locking Rear Diff
If it wasn't for the last minute, nothing would ever get done.
1953 3800 - SRW C&C Dump - 216/SM420
1985 K30 Scottsdale - SRW - 6.2/SM465/NP205 (Sold)
Cheng is offline   Reply With Quote
Old 02-17-2012, 04:30 PM   #2
Cheng
Junior Member
Re: '85 One Ton SRW Diesel
The Truck was special ordered by Arco Oil & Gas and delivery was made 01-09-1985 in Dallas, Tx.
Upon vehicle delivery it was shipped to Nigeria to work in the oil fields as the drilling foreman’s personal truck where it remained until 1993 when the drilling operation was shut don and all personnel and equipment was returned to the US.
Upon repatriation Arco Oil & Gas sold the vehicle to the Drilling Foreman for use on his ranch where the truck remained until December 2011 when I purchased the vehicle.
It came with the complete set of records and only had 93,000 Original Miles when I flew out to Houston and after only changing all the fluids drove the truck back here to Jacksonville, FL.
So even though this is now a Three Owner Truck it has only ever had two main Drivers!
Here are the RPO Codes:
A01 – TINTED GLASS-ALL WIN
A28 – SLIDING REAR WINDOW
C60 – AIR CONDITIONING–FRO
D45 – EXT. BELOW-EYE-LINE-
E63 – FLEETSIDE BODY
GT5 – REAR AXLE – 4.10 RAT
G80 – LOCKING DIFFERENTIAL
LL4 – 6.2 LITER DIESEL ENG
MM4 – 4-SPEED MANUAL TRANS
NL2 – AUXILIARY FUEL TANK
NY7 – TRANSFER CASE SHIELD
P13 – SIDE MTD. SPARE WHEEL
R04 – SINGLE REAR WHEELS
UF2 – CARGO AREA LAMP
U63 – AM RADIO
XYT – LT235/85R-16E TBL OO
YYT – LT235/85R-16E TBL OO
ZV1 – MSO REQUIREMENTS
ZYT – LT235/85R-16E TBL OO
ZY1 – SOLID PAINT
Z53 – GAGES – VOLTMETER, O
Z62 – SCOTTSDALE EQUIPMENT
62W – XSS1 SADDLE TAN CUS
66L – 66 INDIAN BRONZE MET
Old 02-17-2012, 04:32 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Sharp truck!
--Josh
Old 02-17-2012, 04:49 PM   #4
Cheng
Junior Member
The first item of business when I got home was to fix the Glow Plug Control circuit.
The problem I had was that the truck would never glow for more than 5 seconds even when it was in the 20's a few nights.
First thing i did was to check all of the glow plugs. I did this by removing them one by one and connecting them to a hot battery.
I found that only 4 of the plugs were still any good and this still didn't explain my short glow timing. While I had them all out I went ahead and replaced all 8 Glow Plugs with AC Delco 60Gs. I liked the fact that they were self-regulating but they definitely heat up much slower.
After verifying good battery voltage to the controller and that the engine temp switch and starter engaged signals were functioning properly I narrowed down my problem to be the Glow Plug Controller itself.
After reading many posts on here and elsewhere about the never ending problems with this circuit I made the decision to convert this truck to a Manual Glow Control Set-up.
I did the conversion using a Starter Solenoid for a Ford 351w V-8 and a Momentary Push Button inside the cab.
Ever since these modifications the truck starts easily no matter how long it has been sitting or what the outside temperature is. As an added bonus I don't think anyone else could get my truck started and take off in it!
Old 02-23-2012, 10:39 AM   #5
Cheng
Junior Member
Power steering pump has been getting steadily worse for the last month and started getting a leak at the pitman arm seal on the steering box.
So yesterday I decided to do something about it.
Started by pressure washing the engine bay, then removed the power steering pump and the steering box.
Overhauled the power steering pump yesterday afternoon and hoping to get to the power steering box today.
It always amazes me how many seals and o-rings are in the steering box.
Old 03-07-2012, 12:29 PM   #6
Cheng
Junior Member
Finished the power steering box last week and it is so nice to have power steering back again!
Old 03-08-2012, 01:29 PM   #7
rs72z
rs72z's Avatar
For future reference when you need to check the glow plugs, you dont have to remove them. Un hook the wires from all the glow plugs, next hook the a test light to positive post on the battery and touch the spade on the glow plug. If the light lights the plug is good if it doesn't the plug is bad.
Nice truck by the way.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
1985, 4x4, k30, project, srw
