Old 05-02-2003, 02:04 PM   #1
jayssunm
jayssunm's Avatar
WTB: 1" or 1 1/2" lowering block for coil spring axle
Does anyone have a set of lowering blocks for a coil spring rear end laying around? Now that I have the axles I need to lower the back end so I can get ready for my C-Notch.
Cheers,
Jay
67 Fleetside Shortie, small window, slip & slide tranny
Upgrades--small block, tilt column, disc 5 lug conversion (front and rear),
Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG)
jayssunm is offline   Reply With Quote
Old 05-03-2003, 07:44 AM   #2
MOTHERTRUCKERS
How low are you planning to go in the rear? I can make the blocks with the proper degree built in for coil spring rears here in Fl and have notch kits, adj panhard bars and drop coils in Ca to save you on shipping cost and Ca state taxes.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
