Old 03-02-2012, 10:53 PM   #1
AngryPirate
AngryPirate's Avatar
Is this really the best option for a master cylinder?
http://www.autopartswarehouse.com/sk...dot-80002.html
It's for my 1961 with an auto trans, no power booster and all drums.
I guess I want to make sure I'm spending my money on the best option for my set up without moving up to a power booster system.
Thanks,
Scott
AngryPirate is offline   Reply With Quote
Old 03-02-2012, 11:29 PM   #2
dan42
dan42's Avatar
Re: Is this really the best option for a master cylinder?
It's 70 bucks - hard to get killed to bad on that one. Check it out and let us know.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-02-2012, 11:37 PM   #3
AngryPirate
I'm happy to spend more if I can get something that offers more braking power.
It's more of a statement of performance for my current configuration rather than looking for the cheapest price.
Mostly, can you use master cylinders from other, newer years that may perform better?
Old 03-03-2012, 12:20 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Were you planning on splitting the lines? I'm not familiar with the earlier trucks but I would split the lines if I were rebuilding. I used the 'Corvette' ms/cyl on my '66.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-03-2012, 12:25 AM   #5
AngryPirate
ha! I might look into that. Thanks. split lines and proportioning valve, right?
Old 03-03-2012, 12:29 AM   #6
jocko
jocko's Avatar
no prop valve needed, you are 4 wheel drums. 67 C10 MANUAL brake master cylinder works nice also. Will post a linky when I can find it - chief rocka has a good thread also.
Old 03-03-2012, 12:31 AM   #7
AngryPirate
Thanks jocko.
Old 03-03-2012, 12:31 AM   #8
jocko
jocko's Avatar
here you go: http://67-72chevytrucks.com/vboard/s...d.php?t=487384 (also note chief rocka's thread is embedded at post #12)
Old 03-03-2012, 12:37 AM   #9
AngryPirate
sweet. I check it out.
thanks again.
Old 03-03-2012, 12:45 AM   #10
protrash64
protrash64's Avatar
Yes, I'm just not familiar with what bolts to the earlier set up. Do you have the integrated clutch cyl. too?
You can definitely do it for less than I spent on this set-up using factory parts.
Old 03-03-2012, 01:31 AM   #11
AngryPirate
It used to have an integrated master cylinder before the transmission got swapped out to an automatic from a manual.
I'll have to do some measuring and stuff and also add a plate to cover the up the clutch hole much like they did in this thread
All the tips and pointers are much appreciated.
brakes, master cylinder
