Old 03-06-2012, 03:02 PM   #1
kanicsar
1986 silverado dual fuel tank system
so i am going to replace both my tanks and sending units and the fuel tank selector valve "which i have no choice but to use a universal one" i cant find a true aftermarket replacement. i am being told that i have to install a after market switch does anyone know if i can just use the factory installed switch?
and i am having trouble with my fuel gauge its all over the place either on empty or pegged past full. if you tap on the gauge bezzel the gauge will i assume read the actual fuel level. i have tried to taking the cluster out of the dash and cleaning and tighting the connections but there is no change.
any ideas thank for all your help!!!!
kanicsar is offline   Reply With Quote
Old 03-06-2012, 05:16 PM   #2
jhngardner367
jhngardner367's Avatar
Re: 1986 silverado dual fuel tank system
AutoZone lists 2 types of replacement valves.one($49.99),you have to use a different switch,and the more expensive($89.99),has an adapter,to accept the stock wiring.GM no longer offers a replacement.
As for your gauges,it,s probably the same thing mine did,and I ended up putting in an extra ground, on EACH gauge,and running them to a single ground wire,and to a good ground on the body.
Those little "pinch-type" connectors,that the gauge pins slide into, lose their tension,and a simple bump can break the ground contact,causing you to "tap" the bezel,to get it working.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-06-2012, 09:00 PM   #3
broey
Square
broey's Avatar
check your grounds at the sending units. also, I got a switch from napa that looked identical to the factory switch.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 03-07-2012, 12:21 AM   #4
orbot
orbot's Avatar
Yes, check the grounds i had the same issue on one side and it was a bad ground... as for the switch i bought mine at autozone for $15
orbot is offline   Reply With Quote
Old 03-07-2012, 02:59 AM   #5
Desert1957
Desert1957's Avatar
The "Factory" fuel switching valve is available
"Pollack" http://www.jcwhitney.com/motor-drive.../p2005712.jcwx
Desert
Desert1957 is offline   Reply With Quote
Old 03-07-2012, 03:12 AM   #6
gramps77
LMC has one that was EXACTLY the replacement for what I had. Check their versions.
gramps77 is offline   Reply With Quote
Old 03-07-2012, 11:16 AM   #7
wyattglock
wyattglock's Avatar
I got both the fuel switch and selector valve at my local Napa. I probably paid more than I should have, but they had them in stock.
wyattglock is offline   Reply With Quote
Old 03-07-2012, 11:55 AM   #8
Desert1957
Desert1957's Avatar
Good Tip
Old 03-07-2012, 01:44 PM   #9
kunsan1987
kunsan1987's Avatar
wells part #
selector valve FSV1
switch SW411
available at both autozone and my local napa
kunsan1987 is offline   Reply With Quote
