Old 03-12-2012, 06:17 PM   #1
hartbraker
86 Chevy K30 Cummins Swap
Just bout a 1994 Dodge 2500 12 valve p pump with 147K original miles NV4500 4x4 5 speed manual with dana 60 front and dana 80 rear. I'm going to get rid of the 454 BBC out of my 1986 Chevy K30 along with the TH400 and try to reuse the NP205 by getting some gooding for the NV4500 so that I can convert the NV4500 tailshaft and housing to adjust to the 32 spline input shaft of the NP205 out of the 86 NP205 with the round 6 bolt patter.
I will be posting pictures of the two trucks and both motors. The big block and tranny only have 90k original miles on them, but it's time for a serious upgrade. Cummins makes it, chevy shakes it!
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 03-12-2012, 06:20 PM   #2
hartbraker
Re: 86 Chevy K30 Cummins Swap
I have two different options, I can either try to find a pre 93' np205 out of a dodge... which is only a 29 spline but will be a direct fit to the back of the NV4500. (cheaper route, but potentially weaker) OR I can buy a whole new tail housing, main shaft, fifth gear and nut, so that my GM 32 spline NP205 will bolt up directly to the NV4500.($500 plus freight) STICKER SHOCK!!! The 32 spline is definitely stronger, but I don't know how much. Opinions, thoughts, suggestions... anyone's $0.02 is welcome.
Old 03-12-2012, 08:42 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Stronger is better. Then make that diesel roll some coal!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-13-2012, 02:46 AM   #4
andrewmp6
I would spend the money and build it once.If there is a weak link you will find it with a diesel lol.
andrewmp6 is offline   Reply With Quote
Old 03-13-2012, 09:10 AM   #5
Chevyman350
the round pattern dodge 205s are sought after and are harder to find. Or so I have heard in my lurking on the cummins swap boards.
Chevyman350 is offline   Reply With Quote
Old 03-13-2012, 10:33 AM   #6
72longhornTX
There are a few different ways you can do the transmission. You can used the whole setup out of the Dodge and just use the driver side drop D60 out of the Dodge. That works fine although it isn't the normal Chevy passenger side drop. Also that offers more room for the exhaust on the passenger side. Or you can go with your idea of finding a older Dodge np205 or swapping the main shaft to 32 spline. Since you already have the Dodge I would just use the axle.
Current:
2012 Ford F-250 4x4 6.7 Powerstroke
1971 C-20 2wd 350/TH400
Former:
1979 C-20 2wd 350/TH400, 300+hp. Rattle can paint job
1982 K-30 454/700R4. 4in lift with 37" Goodyear MT/R's Lots of goodies - Trail clean up truck
72longhornTX is offline   Reply With Quote
Old 03-13-2012, 12:30 PM   #7
hartbraker
Well, my only argument about the 29 spline being a weak link is that the dodge currently has a 29 spline and why fix what isn't broke? If it does turn out to be quite difficult and just as expensive to find a working round pattern dodge np205, then I agree just build it once, and get the 32 spline setup.
HOWEVER, 72longhorn while I hear you on the axle swap... I'd have to rebuild the entire gear setup as the dodge dana 60 has 353's(I believe) and my build will have 410 gears. Not to mention the added time and fabbing required to get rid of the coil overs and revert to the leaf springs... TOO MUCH for my taste.
Old 03-13-2012, 12:37 PM   #8
72longhornTX
True on the 29 spline issue. The Allison trans uses a 29 spline as well behind the Duramaxs so it is plenty strong.
I hear you on the whole coil to leaf conversion on the axles.
Now I will say my knowledge on trucks has not extended down to the axles so would it not be possible to just take your ring gear and pinion gear out of the GM Dana 60 and bolt them into the Dodge Dana 60?
Current:
Former:
Old 03-13-2012, 01:36 PM   #9
hartbraker
That I do not know. I'd have to say that would be a useful piece of information... but if I were going to do anything, I'd want to try to use the dana 80 from the dodge in the rear and take out my current corporate 14 bolt. But again... the who rebuilding the running gear is expensive and might have to wait til down the road when I have more money to light on fire.
Old 03-13-2012, 02:18 PM   #10
yousesteers
If you have a 32 spline tranfser case with the large bearing you can put a 29 spline shaft in their to my understanding. I used a 29 spline 205 from a 1991 Dodge in mine and have been looking for one for almost 6 months for another project have yet to find it
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 03-13-2012, 09:07 PM   #11
Fixwhataintbroke
Enthusiast
Fixwhataintbroke's Avatar
here's a very thorough (and long) article regarding the dana 60
http://www.pirate4x4.com/tech/billavista/60_front/
- Cole
1979 Chevy C30 w/ carb 454.
1992 Chevy K1500 w/ tbi 350. *Sold*
1997 Dodge Ram 1500 w/ Magnum 360 *Sold*
"Good judgment comes from experience. Experience comes from poor judgment." - George Washington
Fixwhataintbroke is offline   Reply With Quote
Old 03-14-2012, 12:33 PM   #12
72longhornTX
Thanks for the link. Much needed article to read. Never hurts to learn something new.
Current:
Former:
Old 05-01-2012, 03:39 PM   #13
hartbraker
Well update: UNFORTUNATELY, my dodge was destroyed in an accident. Everyone is ok, thankfully... but the truck and motor are not. So I've decided to take the money that I'll get from insurance and rebuild the 454 that is in the truck now. I'll save the cummins swap for a future driver, and keep my current 454 for a toy/firewood truck/hauler. The 454 plans are to make into a 496 stroker and twin turbo... As soon as the motor starts coming out I'll post picks of the build. Stay tuned.
Old 05-01-2012, 04:06 PM   #14
Stew_Magoo
I like the way you think. That sounds like the cheapest and easiest route. Plus i like the idea of not having to dick around routing 4 inch exhaust around the transfer case.
Stew_Magoo is offline   Reply With Quote
Old 05-03-2012, 10:02 PM   #15
Edahall
Wow, must have been a pretty bad accident to destroy the engine.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
4x4 454, cummins swap, repower
