03-20-2012, 07:59 PM | #1 |
Bed Removal
How exactly do you get to the nuts underneath the frame rail when you remove the bed? And do you use an impact gun because I don't really see a way to get up in the frame rail with one. So what have you all done when removing the bolts? Thanks.
1985 Chevrolet K10 Custom Deluxe---SOLD 1997 Ram 2500 5.9 Cummins 1985 Chevrolet Camaro Z28 1987 Chevrolet K10 Silverado "The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257 |
03-20-2012, 08:05 PM | #2 |
Re: Bed Removal
Mine is a 1985 also. They were so rusty I ended up cutting them with a torch.
03-20-2012, 08:11 PM | #3 |
Re: Bed Removal
Yeah that will be my last resort, I would prefer to keep the bolts intact if I can.
03-20-2012, 08:11 PM | #4 |
Re: Bed Removal
hope you get an answer man. good luck.
03-20-2012, 08:12 PM | #5 |
Re: Bed Removal
I used a regular socket and a swivel extension - or just a regular box end wrench.
Also - a couple of them might have corresponding holes in the frame rails - you can feed your extension through the hole, put the socket on one end and the breaker bar on the other, and then get a straight shot. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-20-2012, 08:14 PM | #6 | |
Re: Bed Removal
03-20-2012, 08:16 PM | #7 |
Re: Bed Removal
I've always cleaned the threads, use a cheater to brake loose, then air ratchet them off. The ones that don't come off, cut'em.
03-20-2012, 08:18 PM | #8 |
Re: Bed Removal
My problem is not how to do it, but how to get to it with tools.
03-20-2012, 08:26 PM | #9 |
Re: Bed Removal
Okay the green is the bed floor, the black is the frame, the red is the bolt, and the blue is the nut. How do you get tools up into the black area underneath the blue nut? Hope this helps.
03-20-2012, 09:01 PM | #10 |
Re: Bed Removal
Take and put a breaker bar with a socket and break them loose.
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
03-20-2012, 09:08 PM | #11 |
Re: Bed Removal
Okay thanks, visuals help me more than words.
03-20-2012, 09:11 PM | #12 |
Re: Bed Removal
I wanna play...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy? |
03-20-2012, 09:38 PM | #13 |
Re: Bed Removal
Ha.. that is great, I will show you guys something neat with this program tomorrow.
03-20-2012, 10:03 PM | #14 |
Re: Bed Removal
clean the threads the best u can , small wire brush and some PB blaster. if you skip this step the nut may start to bind up at about half way off.....you then run the risk of rounding out the square hole in the bed the bolts set in.......no fun after that..
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
03-20-2012, 11:47 PM | #15 |
Re: Bed Removal
hahaha nice picture vegas80step!
03-21-2012, 08:43 AM | #16 |
Re: Bed Removal
Lol -
k
03-21-2012, 09:30 AM | #17 |
Re: Bed Removal
PB blaster and a wire brush is going to be your best friend clean the threads of the bolts good and soak them up good with some PB blaster then use a breaker bar(preferably the longer the better) just remeber leverage is your friend. Also don’t forget about removing the wiring harness going to the tail lights, filler neck, and there might be a ground strap at the filler neck. then your ready to remove the bed, grab a 4x4 post and cut it to length so it can lay between the bed sides near the middle of the bed an that gives you a good place to hook a cherry picker and pick up the bed, or you could get about 6 guys and that will be plenty to pick up the bed if you don’t have a cherry picker
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod |
03-21-2012, 11:25 AM | #18 |
Re: Bed Removal
Don't forget safety glasses! sux crap falling in your eyes
03-21-2012, 08:35 PM | #19 |
Re: Bed Removal
Told you guys I would post pics of something cool with this program. I use it to try out ideas on "my truck" before I decide I want to do something.
03-21-2012, 08:55 PM | #20 |
Re: Bed Removal
thats cool...
03-21-2012, 08:56 PM | #21 |
Re: Bed Removal
Lot more where that came from. Will get more pictures.
03-21-2012, 09:15 PM | #22 |
Re: Bed Removal
More
03-21-2012, 10:59 PM | #23 |
Re: Bed Removal
one question, What is that program called????? i have to get it!
03-22-2012, 06:07 AM | #24 | |
Re: Bed Removal
Pre Built Models: http://sketchup.google.com/3dwarehouse/?hl=en Lots of cool stuff.
03-22-2012, 12:26 PM | #25 |
Re: Bed Removal
You could cut a hole in the frame then just run the socket straight up to the nut.
