04-03-2012, 11:42 PM | #1 |
1 thing at a time is progress.
Custom cab trim hole layout
I did a several searches, but couldn't pull it up.
I've seen pics out of the factory service manuals that actually has the hole spacing. If you have a link please share or post the pics here. I'm mainly needing the fender, but all would be helpful. Thanks
Alan
Philippians 2:14-16 |
04-04-2012, 12:04 AM | #2 |
Re: Custom cab trim hole layout
I'm not at my computer at the moment, but I posted that on here for someone in recent months. I'll try to reminder to get it to you.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
04-04-2012, 12:08 AM | #3 |
Here is the page with your previous post. I saved it in case I have to replace a fender or something.
http://67-72chevytrucks.com/vboard/s...77#post5142277
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
04-04-2012, 12:13 AM | #4 | ||
Alan
04-05-2012, 04:25 PM | #5 |
"wrench, Alan, wrench!"
-W |
04-05-2012, 11:04 PM | #6 |
I'm trying to get it ready for our get together in 2 weeks.
Alan
04-06-2012, 03:15 PM | #7 |
Did you get your 88 or so holes drilled yet? The nice thing about drilling the holes is you can get it all lined up perfect with the way the body is setting, provided you got the body lined up well. Are you going to paint in between the trim on the bed?
04-07-2012, 12:53 AM | #8 | |
Drilled the holes in the door and fender on both sides. I used a laser level to get a straight line from the holes that were already in the bed and cab corner. I had an old door that had trim holes so I made a template and lined it up with the laser line. Then I used a self firing center punch, 1/8" bit and a unibit. There are 2 different size holes. The yellow touch up stick was used to paint the bare metal. I'm ready to paint the silver between the mouldings. Waiting on the new mouldings from Mar-K, should be here next week. Had a little issue with the trim, but they are taking care of it.
Alan
04-07-2012, 03:36 AM | #9 |
But Found Her 25yrs Later!
Are the holes located in some exact location along the length of the bed, or are they just so many inches apart?
I have a couple longbed sides that I might cut down to shortbed and was curious how that would effect the hole locations. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
04-07-2012, 01:13 PM | #10 |
i was wondering the same thing..from the looks of the pictures it seems the clips slide along the trim. so the holes dont have to be in any exact location. Correct me if im wrong, because once i receive my trim i was gonna check it out, and maybe just use a level and drill holes every so many inches and call it done.
04-07-2012, 07:48 PM | #11 | |
04-09-2012, 12:53 PM | #12 |
I don't want to hijack your thread Alan, but I'm hoping to draw on the expertise of this crowd related to this subject. I started mocking up the side trim that I got this weekend and I ran into a problem on the driver's side bed panel. The holes on the side of the bed appear to be spaced out per the factory specs above, but the trim line is about 1/8 of an inch higher than the rest of the trim. It's tough to tell from this picture, but I can take more when I get home with the trim on.
When I mount the trim in the holes, it's immediately noticable. Has anyone ever seen this misalignment from the factory or should I assume that the panel has been replaced and drilled incorrectly? I'm trying to decide if I should start looking for another side panel. This one has some body filler on it and the back bumper area is damaged. I think it may be easier to just replace the entire panel if I can find a good one. Any thoughts would be appreciated.
04-09-2012, 01:28 PM | #13 | |
ron |
04-09-2012, 01:55 PM | #14 |
No I did not not. When I purchased the truck, it didn't have the trim with it and the PO stated that he purchased it that way.
04-09-2012, 02:00 PM | #15 |
I take it the pass side is fine? I had to put some shims under my rear cab mounts to get mine lined up after checking other things that was the simplest thing to do. It might be the right thing for yours. If your pass side is good, then look from the rear about 20' behind the truck and look over the bed and see if it level with the cab.
Alan
04-09-2012, 02:07 PM | #16 | |
on |
04-09-2012, 02:58 PM | #17 |
Perhaps the bed used to be on a different truck and someone drilled them too high.
04-09-2012, 06:02 PM | #18 |
Thanks all for the input. The bed looks level from the back and all of the body lines match up from cab to bed. The truck was originally saddly in color. Through the blue primer, I can see saddle coloring on the inside of the bed, so I'm assuming this is the original bed. With that said, the driver's side of the bed is the only place that I can find a large of amount of body filler. That's what leads me to believe that perhaps the lower section of the bed on that side was replaced and the holes were drilled too high.
Perhaps they will need to be filled and new ones drilled or I may just replace that side if I can find a good original side. I'm not a body guy, so I'll leave that part to the pros when I get to that stage. I was just hoping to be able to use the trim until I eventually got around to painting it.
