Hand Crafted C-10
![]() Join Date: Aug 2006
Tires past their safe age
I posted a comment in 67-72 concerning the safety of
out-of-date tires and I think it deserves repeating here. The bonding agents in tires deteriorate, not only through heat and use but also through degradation by being subjected to oxygen. Recommended is no more than 6-10 years old. Next time you buy new tires from a dealer, check the date code on the back. Many dealers might store tires for years so ask to pick out your own tire...find the newest. If the dealer refuses, theres probably a reason...go elsewhere. Never forget the tiny footprint your four tires roll on. Never forget the tire may look great and might not be. The code should look something like the illustration. . Last edited by ETsC10; 09-30-2012 at 10:29 AM. |
Re: Tires past their safe age
Thanks, I had to replace the battery's in my motorhome this spring! It's a 08 and the batteries were 07. I checked my tires and they are 07 also I have less than 20,000 miles on them but I'm replacing them before I take my summer vacation. It costs a lot less to do it before your on the ROAD!!!!
Thanks...that is good info!
Yeah-I had to go through this very thing last week. I was having some tires and wheels swapped around, and the tire store guy flat refused to re-mount my spare. Something about it being 27 years past it's out-dated date.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#5 | |
Hand Crafted C-10
You sir should carry a jack. ![]() (jk) ![]()
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
Yeah we used to run used Indy 500 tires on our cars back in the 60's and 70's
Low profile had not come out yet. We learned then about compounds when the state banned us from using them on the street. |
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
Very good info! Most people do not realize the importance of the shelf life of tires. I always try to buy tires that will be worn out within 6 years otherwise its just throwing away money when you have to replace them due to expiration even tho the tread is still good....
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
Tire companies do not warrant tires past 8 years old no matter how good the tread looks. Your local tire store may do something for a good customer but it's on their own dime.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Never blown out a tire in 30 plus years of driving. I do plan on running fresh tires once I've done all the proper burnouts 1st!
"I feel the need for speed!"... as soon as I am done with my nap. |
Here's a lot more tire info-
http://www.tirerack.com/tires/tirete....jsp?techid=11 Worth reading! Mike. ![]() |
Hand Crafted C-10
Right on Mike! This subject is so important and too often ignored.
Plus you've given us a lot of valuable links ... great Safety-related read! BTW--I'm now glad I brouht this to the top again when so many of us might be strapping on our winter tred soon. Thanks for the link Mike...great resource!
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... Last edited by ETsC10; 08-30-2012 at 11:52 PM. |
You're welcome!
Now,if people will take the time to read it all! I've also found that the only American made tires are Cooper and Kelly Springfield.Cooper made here in Mississippi. The rest are from anywhere! Mike. ![]() ![]() |
#13 |
![]() Join Date: Sep 2005
i know my rear tires on my f-150 been on the back for going on 11 years still have good tread but i'm starting to get scared of them
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#14 |
#15 |
O.K,that's 3 brands now!
![]() Mike. ![]() ![]() |
#16 |
While we are at it..Lets mention the problems that can arise from buying used tires! Very dangerous.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#17 |
Hand Crafted C-10
#18 |
I bought my 67 still with Bias Ply tires on it. I think they are a couple years old now, can't find the date code.
![]() Adam |
#19 | |
Hand Crafted C-10
![]() Adam, look for an embossed pad on the tire. The TIN (tire identification number) formats changed over the years so you might find a pad with just 3 digits or many. With this info, we can probably date the tire. Also note if you see DOT embossed on it or a little triangle near the pad. |
#20 | |
Heres something to read and mull over, that is not sponsored by any tire sellers;
http://www.motor.com/article.asp?article_ID=1371 Bottom line, inspect the physical condition of the tires. Unless they've been sitting in the sun, they probably be fine. Quote:
Alex. |
#21 | |
Adam Posted via Mobile Device |
#22 | ||
Hand Crafted C-10
Seeing opinions, both pro & con, can be a good thing. Quote:
The second digits should indicate the use and/or mold the factory used. Date wise, it was made the 49th week of ??? ...if there is a little triangle near the TIN, it would be 1998. If there isn’t; it could have been made in 1998, 1988, 1978 or… There is such muddled info on reading older tires that every time I tried to tackle this I came up with different results. Anyone else want to give it a shot? Last edited by ETsC10; 10-01-2012 at 09:44 AM. |
#23 | |
Adam |
#24 |
Hand Crafted C-10
TTT for safe summer cruising!
#25 |
Yes radial tires go bad when they age. Brand new radials commonly fail. Bias ply tires if kept properly inflated can still be usable for decades. The 8ply rated bias rough tread tires that are on my stock trailer have a date of 035. and they have tubes are inflated to 60 LBS. I pulled them off a 4 wheel drive and put them on my trailer 12 years ago. never had any flats and the bias follow better than radials. They are weather cracked but Im going to use them until they fail. I hauled cattle to Ash Flat Ark last month a 100 mile round trip. No problems or worries. Pulled it with my 66 GMC that also has used older bias tires. My tilt top trailer has very old 15 in 12 ply bias mounted on split rims. they originally where on a lowboy trailer that hauled bulldozers. Same thing they have tubes and 100 lbs of air give me good service. . Ive got some 825 &900 20 bias tires still in service on 2 ton truck,s that are 40 years old. Go to any tire shop look at the discards you will see plenty of radials with deep tread and the bias ply will be worn slick. Radials become junk very quickly. Ill run a bias as long as its round & black and still holds air. I was running a set of ancient 19.5 rough tread bias on the rear of my 64 chev 3/4 a few years ago. Part of the tread came off. never went flat. however I was doing a steady 68Mph on a hot day on the 4 lane 67. had been to little rock and was returning home when it came apart near Bradford ar.
I never even slowed up made it home Ok. |
Tags |
tire date codes, tire safety, tire shelf life |
