Old 04-09-2012, 01:51 PM   #1
vjjack04
vjjack04's Avatar
Long water pump in 55 (2nd series)
Folks,
I cant remember if this has been posted, but need some info. I have long water pump and want to ensure no problem withe stock rediator...I think there is no problem - anyone with experience?
vjjack04 is offline   Reply With Quote
Old 04-09-2012, 10:52 PM   #2
Rude Dude
Rude Dude's Avatar
Re: Long water pump in 55 (2nd series)
As long as it is not a reverse flow pump you should be okay.
Originally Posted by vjjack04 View Post
Folks,
Rude Dude is offline   Reply With Quote
Old 04-09-2012, 10:56 PM   #3
vjjack04
vjjack04's Avatar
I am/was concerned about the clearance to the fan. I am not familar with a reverse flow....is that for a serpentine system?
Old 04-09-2012, 11:23 PM   #4
Rude Dude
Rude Dude's Avatar
Yes
Old 04-10-2012, 02:28 PM   #5
Amorget
What is the issue with the reverse flow pump?
Amorget is offline   Reply With Quote
Old 04-10-2012, 04:05 PM   #6
OrrieG
OrrieG's Avatar
Here is my 350 in stock location with a long water pump. This is with the radiator in the stock 6 cylinder location. It is a big truck radiator which is 1" thicker than 1/2-3/4 ton units. If your radiator is a factory V8 setup it will be closer to the engine and you may have problems.
OrrieG is offline   Reply With Quote
Old 04-10-2012, 09:09 PM   #7
_Ogre
_Ogre's Avatar
long pump here too
can't see it being any interference
shop air compressor timer
Old 04-10-2012, 11:53 PM   #8
vjjack04
vjjack04's Avatar
Originally Posted by _Ogre View Post
long pump here too
Thanks,
Your radiator looks the same as what I have....orieG looks to have an inch or better spacer after the pulley, in front of the fan....
Old 04-11-2012, 01:06 AM   #9
OrrieG
OrrieG's Avatar
Thanks,
With out measuring it I think it was 1" spacer to center the fan in the shroud opening. Leaves 2" or so between the fan and radiator. I ran the same setup with a 283, std radiator and short water pump for 15 years with out a problem. Shroud really helped.
