04-14-2012, 08:33 PM | #1 |
72 C10 with Leaf Springs?
What do you guys think. Is this factory? I thought all 72 C10's had coils in the rear. What would it take to swap over to a coil spring rear with trailing arms?
04-14-2012, 08:39 PM | #2 |
Re: 72 C10 with Leaf Springs?
I believe it could be ordered with leaf springs ,why would you want to go to coils ? I would think leaf springs would ride and haul better than coils but not 100% sure on that.
04-14-2012, 08:49 PM | #3 |
In the event that I wanted to lower the truck's ride height. Coil springs are much cheaper than leafs. I am trying to find out what would be involved to do the swap and if it's worth the effort to save money.
04-14-2012, 08:51 PM | #4 |
Some came with leaf. If you did want to change over to a coil rear end, First check under your truck cause in my case "leaf spring rear" also had a trailing arm cross member on the frame as well. so then you just need the brackets to attach the trailing arms, a set of arms and the saddles for the rear end plus shock mounts, and a pan hard bar. And you would be pretty much good to go.
04-14-2012, 09:10 PM | #5 |
if your concerned about cost to lower it, a swap would cost way more then a 100 dollar flip kit
04-14-2012, 09:14 PM | #6 |
Now I understand why you want to switch to coils ,you got any more pics of the whole truck ? Would love to see more of it.
04-14-2012, 09:18 PM | #7 | ||
"I ain't nobody, dork."
Most Chevy's were factory coils unless ordered with leaf springs. Unless it is a $X$ then it has leaf springs no matter what.
My '72 GMC has leaf springs and I lowered it roughly 3" in the rear with a 2.5" drop shackles and removing the overload spring. Rides just fine. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-14-2012, 09:29 PM | #8 |
When lowering with shackles or a flip kit, what keeps the axle tube from bottoming out on the frame rails. BTW... thanks for all the replies. Flashed here is link to the pics: http://67-72chevytrucks.com/vboard/s...d.php?t=519596
04-14-2012, 09:38 PM | #9 |
Active Member
Chevy trucks came standard with coil springs, leaf was an option.
GMC came standard with leaf springs, coil was an option. |
04-14-2012, 09:54 PM | #10 |
Thanks for the link ,it looks pretty solid ,much moreso than what I started with .I like it .Good luck with it.
04-14-2012, 10:01 PM | #11 |
Its a Truck Thing......
Me,
Id take coils anyday over leafs, if the truck is right, coils ride 1000% smoother than leaf springs....My opinion..... The frame if it was a leaf will have the dimples put in where the hanger brackets are mounted, coil frames are flat down the back fram rails. That is what I have seen. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
04-14-2012, 11:57 PM | #12 |
I just finished the swap from leafs to coils with trailing arms yesterday. The coils ride much smoother stock for stock, at least on my truck. I lowered it ~5 inches with a flip kit and somehow the ride got worse. Now it's lowered with 3 inch springs (waiting on 1.5 inch blocks) and the ride is night and day better.
You will need the trailing arms, two cross members (between coils and the one where the panhard bar mounts) and the spring mount reinforcing plates.
1972 GMC LWB, 250, 4sp 2010 GMC Sierra 6.6 CCSB |
05-12-2012, 03:37 PM | #13 |
Thanks for all the good posts, i've been debating whether or not to stay coil or switch to leaf i think you all have helped me with my predicament
Scott Daily Driver:2010 Z71 Ext Cab Project:1972 C10 SWB |
04-15-2013, 03:29 PM | #14 | |
Bring up old post. Can you explain the dimples and flat down comment? Slow72 - Any photos and warnings during this process? Did you bolt on brackets to trailing arm cross member/carrier bearing support? If so what did you use for bolts? The factory holes in ours look small, maybe for rivets. Might drill out for larger grade 8 bolts or go aftermarket cross member.
Bob |
02-25-2014, 09:37 PM | #15 |
any pics,im about to do the samething...
