Old 05-03-2012, 09:03 PM   #1
jaybones
1973 C20 292 L6 Low Idle Condition....
Just bought a weekender and quasi-project truck and gave it a good tune up, needed new water pump, hoses, etc. Question is, does anybody else with an early-to-mid 70s have any experience with this low idle condition i'm experiencing?
it doesn't stall out, but the idle is so low (think: sitting at a stop sign) that I have to actually pay attention to whether or not it is still actually running. previous owner was an old-timer who said it had always idled low, and i don't know if i'm just not used to it yet....
any thoughts are appreciated!
jaybones is offline   Reply With Quote
Old 05-03-2012, 09:06 PM   #2
Shane22696
Shane22696's Avatar
Re: 1973 C20 292 L6 Low Idle Condition....
Does it have an idle speed screw on the carb? If so just turn it until it sounds right.
80 K10 350 4 spd
4 Inch lift, 33 inch BFG M/t
Shane22696 is offline   Reply With Quote
Old 05-03-2012, 09:12 PM   #3
jaybones
its a 1bbl Rochester and I looked but nothing "stood out" to me as the idle screw. thoughts on exactly where it would be?
Old 05-03-2012, 09:14 PM   #4
Shane22696
Shane22696's Avatar
Not completely sure on a monojet, but on every other carb I've see they're under the throttle linkage pointing towards the rear of the carb. Hope you get it worked out!
80 K10 350 4 spd
Old 05-03-2012, 09:17 PM   #5
jaybones
thanks man, i'll see if i can't search it out tonight!
Old 05-03-2012, 09:19 PM   #6
Shane22696
Shane22696's Avatar
Not a problem, hope I helped! If you find it turning it to the right should raise the rpms.
80 K10 350 4 spd
Old 05-03-2012, 10:53 PM   #7
jaybones
found it! it's on the front end side of the carb, hidden all the way at the bottom. only reason that i noticed it was because it has a shield with a screwdriver hole out in front of it. figured that the shield was there for a reason and followed it back and found that sucka!
besides the rotted out muffler she's purrin like a kitten now
headers and flowmaster here i come!
Old 05-03-2012, 11:00 PM   #8
Shane22696
Shane22696's Avatar
Glad to hear it man
80 K10 350 4 spd
292, c20, idle
