pinion angle correction blocks?
This may be a stupid question but does anybody know a vendor on this forum that sells the pinion corrector blocks ? I have 5''drop springs and 3'' blocks so I know I need them . Thanks in advance for your help
Re: pinion angle correction blocks?
I have some driveshaft shimmy and wanting to correct it before the HRPT - Thanks
![]() Join Date: Feb 2007
your local alignment shop or tire shop should have them. They will carry both angle shims and angled blocks to fit your needs.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
You can order them through CCP. Or you can order them directly from cv everything racing products. This is the nascars brian vickers uncle i guess. This are exactly what the nascar boys use[ATTACH]
#6 | |
I know this is an old thread but I want to add 1" blocks in the rear to bring my rear down to level with the front. Should I get the angled blocks or am I ok with the regular one. I have 4" rear springs, shock relocators, and adjustable phb. Thanks.
First you need to know if your pinion angle is correct. To figure that out look here.
http://www.drivetrain.com/parts_cata..._problems.html |
Tags |
angle, pinion |
