Old 05-09-2012, 08:29 AM   #1
doodah man
doodah man's Avatar
Question Radiator for 350/TH350 with Vintage Air
I noticed another thread recently asking about what radiator to use for a Vintage Air install. Rather than hijack that thread, which was about a different engine/trans set up, I'm going to start a new one.
I've got a 72 with 350 engine and TH350 trans and I'm slowly installing a Vintage Air system. Right now I've got a single core radiator and 5-blade non-clutch fan and I'm thinking that will need to change. I'm wondering if I can get by with a 3 core radiator and avoid having to get new hold down brackets or if I need to go all the way to a 4 core.
In either case, where can I get a OE replacement 3- or 4-core radiator for a good price? I checked prices in the catalogs and so far LMC has the best price at $290 (for the 4-core). Is there a better price to be had? There's not enough in the budget to go with an aluminum radiator/electric fan.
Thanks in advance, as always.
1972 C-10 Deluxe
350 V8 - 350TH
We're not the jet set
We're the old Chevrolet set
doodah man is offline   Reply With Quote
Old 05-09-2012, 09:22 AM   #2
chopnchaneled
chopnchaneled's Avatar
Re: Radiator for 350/TH350 with Vintage Air
I used a four core from o'reilys 187.00 picked up. and a clutch fan with my vintage air and no problems.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 05-09-2012, 09:30 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I would just go ahead with the 4 core.They last years and I did one from Advance for $200 so it's not much (if any) more expensive.It also gives you plenty of radiator for any future power upgrades(we all want more).With a good clutch fan and shroud,it should cool anything.Keep in mind that the electric fans upgrade(should you go that way) will require more power and may neccesitate an alternator upgrade.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-09-2012, 09:34 AM   #4
jjzepplin
jjzepplin's Avatar
You will have to get wider brackets for the four core. I just lengthened mine. I threw the old ones away not knowing. Learned something-save everything till its been rolling for a year or so.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
radiator, vintage air
