Old 05-12-2012, 09:47 PM   #1
Hotrod 4x4
Hotrod 4x4's Avatar
'68 GMC K20 327cid 350hp??
I have a 68 GMC K20 with the 327 4barrel and 4spd trans. What was the HP on these motors????
Hotrod 4x4 is offline   Reply With Quote
Old 05-14-2012, 12:51 AM   #2
dan42
dan42's Avatar
Re: '68 GMC K20 327cid 350hp??
If it is the original motor probably around 180 - the higher performance motors were in the cars.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-14-2012, 06:46 AM   #3
Hotrod 4x4
Hotrod 4x4's Avatar
Thanks dan42, All the research i have been doing is showing that it maybe a 350hp 327. Anyone else have anything????
Old 05-14-2012, 07:04 AM   #4
cdowns
cdowns's Avatar
not at all original// you've got a correct answer
just keep on dreamin if you get an answer you are disappointed with
Old 05-14-2012, 08:53 AM   #5
Hotrod 4x4
Hotrod 4x4's Avatar
Well im not really that worried about what it is. It just runs great and has a ton of power.
Old 05-14-2012, 10:02 AM   #6
Lee H
Lee H's Avatar
Post up the block casting number, date code, and front pad numbers and we can tell you what the engine was born as.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-14-2012, 10:48 AM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
None of the trucks came with any HP numbers like that.
You'll need to throw some parts at it to get those kind of numbers.
It might run good and have some power. The PO could have put an aftermarket cam and stuff in it. But I doubt it would be pullin' those numbers with just a cam swap as well.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-14-2012, 12:49 PM   #8
Hotrod 4x4
Hotrod 4x4's Avatar
Ill get the numbers some time and post them. Im sure its not anything great. Im just glad it runs good with low miles..
1968 k20 4x4, 327, k20
