Old 05-12-2012, 10:12 PM   #1
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Toro Flow Diesel Engine & Trans
Sold
This was previously posted here: http://67-72chevytrucks.com/vboard/s...d.php?t=493449 but I reposted with the proper South Dakota Prefix.
I'm finished with my Cummins swap, so the old motor has to go. It is a 73 GMC 478DH Toro Flow diesel V6, pretty rare motor. I also put on a gear reduction starter that was machined to fit the block with a custom adapter (spent $500) and it cranks over like clock work. This engine came out of a 73 2.5 Ton dump truck and placed in my 68 back in the late 70s. It runs great and I have a video of it idling while it was in my 68 K20 Suburban.
Included is the transmission which is a 5 speed non synchro truck transmission. It uses a hydraulic master and slave, which I will include. From the information I have GM truck transmissions (large centerbore) will fit to the bellhousing on this motor so you can use a synchro trans if wanted. Also included are all mounts from the engine to the frame and accessories on the engine. The AC compressor is removed, but the power steering pump and alternator are both in their brackets and are included. A mechanical drive diesel tach will complete the package.
This motor is in Sioux Falls. Call me at Edit: (Seven 0 One) 541-7081
$750 for everything, not willing to separate but can negotiate on price and pick-up/delivery.
Final picture is an idle video.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-30-2012, 04:11 PM   #2
lowrollin70gmc
Too many projects
Re: Toro Flow Diesel Engine & Trans
TTT Still for sale hanging out in a corner of the garage.
Andrew
Old 12-04-2012, 02:47 AM   #3
lowrollin70gmc
Too many projects
I know someone wants to sound like a freight train running down the highway. If I can't sell it I'll just have to buy another truck to put it in!
Andrew
Old 12-04-2012, 04:50 AM   #4
nobolt
nobolt's Avatar
that is a sweet rig. what kind of motor mounts are required? what were you getting for mileage? more or less than the cummins?
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 12-04-2012, 11:49 PM   #5
lowrollin70gmc
Too many projects
Motor mounts: It uses a single mount in the center of the front of the motor along with two mounts at the bellhousing. I have the crossmembers/ mounts for both of these.
Mileage: Guessing 15-16 but I never truly tracked the mileage, I just topped off when needed. Definitely less than the Cummins, I've been seeing 18-20 with varying town and highway and no trailer.
Andrew
Old 01-26-2013, 11:41 PM   #6
lowrollin70gmc
Too many projects
Back to the top for a unique combination and new price.
$1000
Andrew
Old 01-27-2013, 12:11 AM   #7
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Thats a really cool engine, Ive never even heard of them. Air cleaners look cool too!
--Josh
Old 01-27-2013, 12:54 PM   #8
Corts60
Just here to tinker
Corts60's Avatar
Unhappy Re: Toro Flow Diesel Engine & Trans
Well I wish you were closer man. I would be into that!
Old 01-27-2013, 07:42 PM   #9
nobolt
nobolt's Avatar
holy smokes! you still have it?
what kind of mods did it take to the 68 burb to install it?
an old GMC suburban/carryall may be my next project. i wouldnt mind buying the right motor a few years ahead of the rest.
Dave
Old 01-27-2013, 10:19 PM   #10
lowrollin70gmc
Too many projects
There were a few plates to bolt the toroflow crossmember to the stock frame and the transmission mounts slid in the frame and crudely bolted on. Unfortunately, the previous owner welded the front plates to my frame so I can't include those, basically a piece of 1/4" x 6" strap bent in a 90* to support the crossmember. The engine isn't any wider than a regular small block but some work would be needed to mount the engine crossmember.
I can get some pictures of the mounts this weekend as I'm heading down to where the motor is stored.
Andrew
Old 02-08-2013, 01:24 AM   #11
lowrollin70gmc
Too many projects
Back to the top.
I will be making a trip from Fargo, ND to Corpus Christi, TX this spring / early summer so if you live somewhere along there delivery is an option!
Andrew
Old 06-20-2013, 10:35 PM   #12
lowrollin70gmc
Too many projects
To the top for $1250 Mr. Trebec.
Andrew
Old 06-20-2013, 11:42 PM   #13
White70C20
White70C20's Avatar
That's pretty awesome. I've always wanted a diesel pickup, seeing as how I'm a truck driver. I'd definatly be interested if it was cheaper.
Oh well.
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
Old 08-09-2013, 06:39 PM   #14
lowrollin70gmc
Too many projects
Still for sale and in need of movement from Sioux Falls to Fargo, so I can negotiate a price if someone's serious.
Andrew
Old 10-28-2013, 11:55 PM   #15
lowrollin70gmc
Too many projects
TTT, local sale pending (for last month, we'll see what happens).
If someone is serious about picking it up, I can probably get the price down to where it'll make it happen.
Andrew
Old 11-02-2013, 08:22 PM   #16
lowrollin70gmc
Too many projects
Bump, $750 until 8th of November, then it's being parted out and the block scrapped.
Andrew
Old 01-11-2014, 02:03 AM   #17
J farm
Do you have any toro flow parts left I have one with a broken crankshaft I'm trying to put back together
J farm is offline   Reply With Quote
Old 01-11-2014, 10:22 PM   #18
lowrollin70gmc
Too many projects
I still have most of the parts, I've got it stripped down to a short block. I'll drop the pan and crank in the next few days/week. Once I get it pulled and weighed I can figure out a shipping cost for you, but I am assuming at least 100lbs. I can do $150 plus shipping. Anything else you're looking for?
Andrew
Old 01-11-2014, 11:49 PM   #19
1969_CM2590D
1969_CM2590D's Avatar
Keeping the tach stuff?
Dennis Nichols
1969 GMC C2500 305E V-6 The Mule
1986 Toyota 4Runner
1959 MG MGA Coupe
1969_CM2590D is offline   Reply With Quote
Old 01-12-2014, 03:42 AM   #20
J farm
If your willing to ship I'm interested in all the toro flow parts you have my name is Jeff my number is 530 559 9775
Old 01-12-2014, 11:52 AM   #21
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Also interested in tach setup
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-14-2014, 02:02 AM   #22
lowrollin70gmc
Too many projects
1969_CM2590D / Vintage Windmills: I still have the tach drive and tachometer itself. The tachometer cable is a standard speedometer cable. My burb was running an aftermarket oil pressure gauge and the rest standard 68 K20 instrumentation, so I only have a tach specialized to the Toroflow.
J farm: I am willing to ship parts, I can even build a pallet for them, but shipping wouldn't be cheap due to the sheer weight of parts. I'll give you a call when I get time tomorrow evening (01/15)
Also, for clarity I do have to bring another small load of parts from Sioux Falls to Fargo. It's only the intake and exhaust manifolds and some small parts, but if there is a serious buyer for those parts I can take a weekend trip down there and retrieve them to ensure everything is together.
Andrew
Old 01-14-2014, 03:44 PM   #23
Vintage Windmills
Vintage 4x4s
shoot me a price shipped on tach setup. i think Im second in line
Old 01-15-2014, 01:36 AM   #24
lowrollin70gmc
Too many projects
The entire setup is pending sale to J Farm.
Andrew
Old 02-03-2014, 10:14 PM   #25
lowrollin70gmc
Too many projects
She's officially sold and I just finished crating it up for a trip back to California. I'm glad it's staying together and nothing is hitting the scrap yard.
Andrew
diesel, k20, rare, toro flow, toroflow
