05-19-2012, 12:43 PM | #1 |
What the heck is going on here?
So this is my first time assembling an engine, and I'm now getting to all the hoses and fittings and such. This is a picture of my engine as it was before I pulled it and rebuilt it. I'm trying to hunt down the fitting that is going from the top of my water pump to my thermostat housing. I'm not sure why that thermostat housing has an add-a-piece and goes down to the water pump, I'm pretty ignorant about all the passageways for coolant and fluids and such. So far I haven't been able to track down the fitting or the hose at any parts house. Anybody know what's going on here?
http://www.flickr.com/photos/72744831@N05/7227843970/ |
05-20-2012, 11:21 PM | #2 |
Re: What the heck is going on here?
It is a bypass used for fast warm up. Never seen it used on a chevy pickup smallblock though. Usually seen on marine engines. My Crusader marine engine had one on it and I did away with it when I rebuilt it and put it in my C10.
05-21-2012, 01:10 AM | #3 |
60-66 Nut
I have seen a couple in pickups, but mostly in medium duty trucks. But it seems like the Corvette's may have had that also? Did you loose the original fitting? There are a couple on this page, but since they are stainless they are spendy.
http://www.summitracing.com/search/P...nless+fittings You could just eliminate the riser under the thermostat housing, and plug the port in top of the water pump, and be just fine. That is how most engines are.
05-21-2012, 08:29 AM | #4 |
jus cap it off you dont need it
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-21-2012, 09:21 AM | #5 |
if i was you i would cap it off...... it really serves no purpose in your application.
thats just my vote and opinion on the deal.
most people sleep peacfully at night because, rough men stand ready to do violenceon there behalf. |
05-21-2012, 09:57 AM | #6 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
05-21-2012, 09:51 PM | #7 | |
Hi Spassmacher,
That looks like the stock bypass hose/adapter setup that was used on many 60's truck 327's. The pickup truck applications like yours used one bypass hose. While the medium duty truck applications used two hoses. If you want to keep the stock bypass setup, the parts you need are still available. I recently went through tracking them down for the 327 we're getting ready to put in dad's 66. The correct moulded rubber hose is Gates #20566. It's available from www.rockauto.com if you can't get it at a local auto parts store. The 90 deg fitting that screws into the top of the water pump was a bit harder to locate. The original has a 1" hose barb and 1/2" NPT threads and is used in conjunction with a 3/4" to 1/2" reducer bushing in the water pump. The closest thing I could find were these fittings on ebay --> http://www.ebay.com/itm/5-FITTING-HO..._Parts&vxp=mtr They're nearly identical to the original except they have 3/4" pipe threads that go directly into the water pump (eliminating the need for the reducer bushing). Quote:
Tags |
hose, housing, pump, thermostat, water |
