Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 05-16-2003, 05:52 AM   #1
79cheyenne4x
79 Blazer, power rear window
The power rear window in the 1979 Blazer I just acquired does not work either by the key switch or the dash switch. Luckily, the window is up. I need to check for power to the motor. Is there a fuse or relay that's just for this window, and if so, where are they? Also, are there any position limit switches in the tailgate? Lastly, who sells the tailgate power window motor for this vehicle?
79cheyenne4x is offline   Reply With Quote
Old 05-17-2003, 12:28 AM   #2
maddog_74k5
about all i can tell u is 1st check all the fusses in ur fuss block if that aint it then the motor/regulator are in the tailgate if its like my 74 u should have an access panel on the inside of your tailgate. now if thats the case what u want to do is take the hard top off carefully (dont break the glass lol) so that u can lower the tailgate to work on it easier. check all your wires and connections(from the tailgate all the way to the switch) if thats all good then u got a bad motor/regulator(if the motor and regulator are one unit u'll need to replace the whole thing if seperate u just need a new motor id say) i hope i was some help good luck
maddog_74k5 is offline   Reply With Quote
Old 05-18-2003, 07:44 PM   #3
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Gregg
If you aren't in too big of a hurry to get the parts for your Power Tailgate Window, one of the guys that I work with is retiring, stripping and scrapping his 80 because of rust. I asked him to give me the entire tailgate if he has no use for it. I'll tear out the power window parts and ship them to you when he gets it to me. George
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 05-19-2003, 06:09 PM   #4
79cheyenne4x
rear tailgate parts offer
Yes, I would certainly appreciate getting my hands on this tailgate window parts. Thanks.
Old 05-21-2003, 03:10 PM   #5
Tobes85K5
It may just be the cable. I had to replace the one on my 85 K5. Can you hear the motor turning when you hit the switch? Take the cable out and then hit the switch.
Tobes85K5 is offline   Reply With Quote
Old 05-22-2003, 11:48 AM   #6
*MJF*
No longer truckless
If you fill out your location, that might help a little. For instance, I have a full power tailgate just taking up space. If you were close to me, I would offer it to you. You would have to bring me a soda as payment for it.
Oh the power of the search button. You are a little far to drive over & pick this thing up.
*MJF* is offline   Reply With Quote
Old 05-28-2003, 08:47 AM   #7
79cheyenne4x
My tailgate
I have not had an opportunity to dig inot this non-functional power window issue yet. There is no noise at all when I activate the tailgate key switch, or the dash switch. My location is suburban Buffalo, NY.
