Old 06-20-2012, 01:20 AM   #1
chevy72blu
chevy72blu's Avatar
Pre oiling after sitting for several years
I am going to pick up my LS1 this weekend. It will be several weeks before I fire it, but this has been in the back of my mind for a while. I have done lots of google university, but I wanted your opinions.
The motor has sat unfired for 4+ years. My plan is simply to pull the valve covers, wet the rockers, crank it for 3x10 secs with the coils/fuel pump fuse pulled to spin the motor up, and light her up. I realize that this isnt the BEST way, but is this a reasonable solution? The goal of this swap is to build an affordable DD with good mileage, not a purpose built track motor... So, I am less freaked out about such things than I was with my BBC.
Will I need to keep my rad cap off to bleed the air out or will the steam port make this unnecessary?
The motor is a stock LS1 out of an 02' F-body with 60k miles (according to the PO, unverified of course).
chevy72blu is offline   Reply With Quote
Old 06-20-2012, 04:44 AM   #2
OKGMC4
OKGMC4's Avatar
Re: Pre oiling after sitting for several years
That's what I did and it worked out. I kept turning until it registered pressure on the guage. My 5.3 sat for 5 years in the garage. There is a special pre oiling tool for LS engines but it's a little expensive. I had to run with the cap off at first, got a ton of air out. Even with the cap on it still felt like forever before the tstat got hot enough to open.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 06-20-2012, 09:01 AM   #3
awhite4557
awhite4557's Avatar
The best way to fill the engine with anti-freeze to prevent an air block is to fill the engine/radiator through the top radiator hose into the engine. Once the radiator fills to the open top hose return, put the hose on and finish filling in the radiator.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2002 Winnebego Class A MH Ford E-550 Chassis V-10
2005 Dodge Ram 2500 5.9 Cummins
2008 GMC Denali
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 06-20-2012, 12:23 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
nutbuster in the combustion chamber, new plugs, fired first crank. Sat for a little over a year.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
