Old 06-21-2012, 05:33 PM   #1
hardhead
Power for stand alone
How many circuits have you used, what parts and where did you get them to power up your truck harness? I know there are several ways to do this and I would like some ideas.
hardhead is offline   Reply With Quote
Old 06-21-2012, 06:00 PM   #2
Daaaanz67
Re: Power for stand alone
Current performance fuse box stinger circuit breaker 80 amp to go between battery feed for fuse box and battery
Daaaanz67 is offline   Reply With Quote
Old 06-21-2012, 09:20 PM   #3
clinebarger
You can use a factory truck under hood fuse box....This the easiest way, No mods to the actual engine harness.
This is a pic of 2tone77's truck that I converted Using a GM under hood fuse box, 05 LQ9/4L65E.
clinebarger is offline   Reply With Quote
Old 06-27-2012, 02:50 PM   #4
hardhead
Too late for the original fuse box. I ditched it when I stripped the truck two years ago. I have all the wires seperated in the same order as stock to the best of my knowledge. I was planning on putting them on seperate fuses and them have a relay to power it all up.
Old 06-27-2012, 09:50 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Thats a nice and clean install...almost like factory.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-27-2012, 09:52 PM   #6
TR65
TR65's Avatar
Hardhead,
I think Clinebarger's setup is the way to go. Wish I had done mine that way.
I bought a surplus fuse box from the Texas Highway Patrol that ran all their accessories. It had all the necessary fuses and relays to allow me to wire every circuit exactly like the diagram in the service manual for the vehicle my engine came out of. But it took a fair amount of work. Two years happy running and no problems.
I run the old truck wiring as a 60 amp fused circuit out of this box as well.
Good luck,
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-27-2012, 10:07 PM   #7
clinebarger
Thanks!
Originally Posted by TR65 View Post
Hardhead,
Good luck,
TR
Yours looks VERY clean, Nice job.
Old 06-28-2012, 09:42 PM   #8
Dustytrix
I used a 6 circuit fuse block from Advance Auto, I then cut the buss into so that 4 circuits are switched thru relays and 2 stay hot. My donor fuse block was way to much trouble to make work like I wanted to.
Dustytrix is offline   Reply With Quote
Old 06-28-2012, 11:33 PM   #9
clinebarger
You have 4 fuses powering 8 Injectors, 8 Coils, 2 O2 heaters, A MAF, & the transmission? I spent alot of time on this thread you started....http://67-72chevytrucks.com/vboard/s...d.php?t=521747 ?
