Old 06-24-2012, 12:52 PM   #1
OKGMC4
OKGMC4's Avatar
Change of gears need retuned?
I'm looking at changing my 3.07 dana 36 rear over to the optional 3.54 or 3.75 gears. What I don't know is does the ecm for my 01' 5.3l have to be changed? Can't the shift points stay the same? And since I have a programmable electronic speedomoter I don't need it there. Just not sure if the ecm uses the gear info for anything else like timing or such. Thanks for any info.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 06-24-2012, 02:13 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Change of gears need retuned?
PCM will need to know. It uses VSS from your trans tailshaft for determining shift points, which will change with the different gear ratio.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
