Old 06-27-2012, 01:48 PM   #1
osaltyone
osaltyone's Avatar
getting P0120 & P2135 codes
Wondering if I have the correct stuff for my motor for the DBW setup. I am getting P0120 & P2135 codes
PCM is programed to be an 06 5.3
SERV. NO. 12589463
Throttle Body is
1257080rme75-
TAC module
12573059
There are no #'s on the pedal
osaltyone is offline   Reply With Quote
Old 06-27-2012, 11:07 PM   #2
ls1nova71
ls1nova71's Avatar
Re: getting P0120 & P2135 codes
'06 should have the all plastic pedal.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-27-2012, 11:14 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
yup, you'd need the molded plastic one. I had the exact opposite problem when I did mine, got the new one needed the old one. Ls1Nova saved me on that one!
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-28-2012, 12:27 AM   #4
osaltyone
osaltyone's Avatar
DAMN! Someone told me I could try to reprogram my PCM to be an 05 and use that pedal/TAC. Do you think it would work? I was told I had an 06 motor, but with the return and reg on the fuel rail and the plastic fuel rails in previous posts everyone thought it was an older engine.
Is the TAC module the same for an 06?
Old 06-28-2012, 07:53 AM   #5
ls1nova71
ls1nova71's Avatar
I think there are different part numbers for them. I have an '06 and can check later tonite and tell you if it's an '06 or not.
Old 06-28-2012, 10:09 AM   #6
osaltyone
osaltyone's Avatar
Thanks! If needed I will buy a 06 pedal, but just want to make sure that is the fix and changing the pcm to an 05 won't fix it. The place I got my engine from said call back next week and they will have one...
I found this pedal on Ebay
http://www.ebay.com/itm/2006-2007-Si...ed6d66&vxp=mtr
Old 06-28-2012, 05:44 PM   #7
ls1nova71
ls1nova71's Avatar
The TAC module you have matches your pedal. It's probably because you have it programmed as an "06. My 2006 TAC has a part number 12590008, so you could either try changing it in the tune, or get an '06 TAC and pedal.
Old 07-08-2012, 12:51 AM   #8
osaltyone
osaltyone's Avatar
So I had the PCM reprogrammed for an 05 and no go. I still get the same codes and no pedal working. When the harness is reworked are there Amy wires changed up / removed that would affect the pedal and tac? I have 2 pedal assemblies, tac modules and cables but get the same codes.
P02135 says throttle/pedal position sensor/switch "A"/"B" voltage correlation
If not the harness then could it be the throttle body? When I turn the key on you can hear it click the servo on the throttle body twice.
Old 07-08-2012, 09:01 PM   #9
clinebarger
Broken wires at the throttle body plug is a common problem on the trucks these engines came from, The odds of them breaking on a swap is really high.
clinebarger is offline   Reply With Quote
Old 07-08-2012, 09:46 PM   #10
osaltyone
osaltyone's Avatar
I read that, and tried pulling in the wires to see if they stretch and show white, but did not notice any. Maybe I will pickup some wire and replace the wire 12" back. I could try to test it on a multimeter, but don't have any clue what I should be getting @ each pin.
Old 10-29-2014, 10:56 AM   #11
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
osaltyone, did you ever solve this issue?
bowtieguy79 is offline   Reply With Quote
Old 11-01-2014, 12:02 AM   #12
osaltyone
osaltyone's Avatar
yep, I swapped my throttle body out for another and it worked fine. Something was up with the old one I guess.
