Old 06-29-2012, 04:48 PM   #1
ScottG
Driveshaft diameter
Is there a difference in the driveshaft diameters of a 1/2 or 3/4 ton? I picked up a '69 c10 with a much smaller diameter shaft than my '67 c20.
'67 C20 LBW
ScottG is offline   Reply With Quote
Old 06-29-2012, 09:45 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Driveshaft diameter
How fast do you plan to run it? I have seen a 1/2 ton ,2 pc shaft to almost to 130? The shaft is built for my longhorn(pretty much 3/4 ton spec)...she runs smooth, @ a tick over 140 ...crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-01-2012, 07:03 PM   #3
clinebarger
I think 1/2 ton's are smaller, But as crazy longhorn pointed out these driveshafts are strong, Ive put 500HP through them with no problem, Even broke a pinion on a 9", But not a driveshaft.
clinebarger is offline   Reply With Quote
Old 07-01-2012, 11:44 PM   #4
Captainfab
60-66 Nut
The smaller diameter driveshafts typically use the carrier bearing that hangs from the top of the trailing arm crossmember. Those carrier bearings are junk IMO. They just don't hold up once you start upping the HP and Torque going thru them. I always go with the heavier duty carrier bearing that bolts to the bottom of the crossmember as you should have in your C20. The C10's were also available with that same HD driveshaft and carrier bearing.
Old 07-02-2012, 12:26 AM   #5
ScottG
That's what confused me. My d-shaft had the bearing you described, and the truck I'm parting out has that skinny shaft. Just seemed so dramatically different, I couldn't see how it would hold up.
'67 C20 LBW
Old 07-02-2012, 08:58 AM   #6
sjarrett71
sjarrett71's Avatar
My last 1/2 ton had the large drive shaft with the horseshoe style carrier bearing. My current 1/2 ton has the smaller shaft with the other style. So I guess they could have either.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-02-2012, 03:37 PM   #7
Captainfab
60-66 Nut
It has been my experience with the C10's that the trucks with the SM420 4 speed typically had the HD driveshaft and the trucks with 3 speeds or auto trans had the lighter duty driveshaft.
Old 07-02-2012, 06:27 PM   #8
crazy longhorn
Yes, that hanger style carrier is the weak point Also that shaft does not have a slip yolk in the middle(pushes /pulls the rubber in the carrier). The shaft itself is plenty strong , for mild to warm street useage tho. after you step up to the 3/4 shaft, with 1350 joints....you will never look back! crazyL
Old 07-02-2012, 06:29 PM   #9
ScottG
Now this all makes sense. The truck I pulled it from was originally a 3 on the tree truck, converted to a T10.
'67 C20 LBW
drive shaft, driveline, driveshaft
