Old 06-30-2012, 10:17 PM   #1
fullup12
fullup12's Avatar
5.3 idle issues
My truck starts easy but dies when cold. As long as you keep your foot on the throttle until it warms up it runs fine (doesn't miss) but will not idle by itself. Once it gets up above about 130 degrees it idles fine. Anyone else have this issue before?
fullup12 is offline   Reply With Quote
Old 07-01-2012, 06:04 AM   #2
OKGMC4
OKGMC4's Avatar
Re: 5.3 idle issues
Take a hard look at your intake gaskets. These motors are notorious for the O ring seals not sealing until warm. As long as its not throwing codes it's easy to assume it's just a vacuum leak. You could try spraying carb cleaner at the base of the intake to see if the idle smooths out. If it is the gaskets they are super easy to change out.
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 07-01-2012, 09:57 AM   #3
fullup12
fullup12's Avatar
Re: 5.3 idle issues
Thanks. I'll try that.
