Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 07-14-2012, 01:38 PM   #1
baller5040
baller5040's Avatar
Where does every one have there wires hooked
I am having a problem with my stereo lately. Been draining my battery ( i only know this because when i unhook my stereo and amp off the battery, it stays fully charged) I am looking for any ideas on how other people have ran the ground and constant and switched wires so it wont eat the battery. The same with the amp as well.
baller5040 is offline   Reply With Quote
Old 07-14-2012, 03:50 PM   #2
76stepsidechevy
Re: Where does every one have there wires hooked
how do you have it wired? Main amp power should be on its own fused wire straight from the battery, remote or switched wire off the stereo's "remote" wire and ground bolted to clean metal as close as possible to the amp. If that remote wires sees power all the time the amp will stay on and can kill your battery.
76stepsidechevy is offline   Reply With Quote
Old 07-14-2012, 08:53 PM   #3
baller5040
baller5040's Avatar
I will have to take a look at the remote wire then. The stereo seems to have good connections. thank you for that idea. Anyone else with ideas?
Old 07-15-2012, 09:11 PM   #4
odog
odog's Avatar
I think 76stepside is right, the remote wire should be the only thing turning your am on. When the key is off, the wire from the deck to the amp tells it to shut off. I just hooked mine up that way today, so lets hope I am right, I dont need a dead battery at 5 am.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 07-16-2012, 03:40 PM   #5
OneOffStroker
It's definitely a remote wire problem. If you don't have a remote wire because you are running some super old stereo or 8-track or whatever, then you would have had to jumper your amp's battery terminal to the remote terminal to get it to ever turn on. If something similar to that is the case, then add a toggle switch to the remote wire and remember to shut it off when you're not in the vehicle.
When I was younger, all of my friends and I used to run toggles on our remote wires anyways. When we were bumping too loud and thought we would get pulled over, we could just hit the switch, thus turning off our amps and when the LEO would check out our cars and hear no bass, but still hear music, we got away every time. lol
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 07-16-2012, 06:12 PM   #6
baller5040
baller5040's Avatar
I think it was that as well i replaced the remote wire in case there might be damage to the other one which was causing the problem. Seems like its not draining the battery but its only been one day!
Old 07-16-2012, 08:41 PM   #7
OneOffStroker
Well, a surefire way to know would be to look at your amp when the truck is all turned off. If the power light is still on, your battery will drain and die.
Old 07-17-2012, 12:46 PM   #8
jimmydean
jimmydean's Avatar
In my first car I used a discman as a head unit and ran a 12v rocker switch in the dash. Hit the switch, press play and I was rocking.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-17-2012, 10:59 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My old zapco 2k monoblock didn't even have a power led
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-19-2012, 12:30 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
I still use a small switch
can be wired to the amp remote as well when needed
and one seperate for subs to turn them off,helps the batt recharge too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-21-2012, 12:58 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
....thats one way of fitting it in there.
Old 07-21-2012, 01:11 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
i think the PO used a hammer ....to din it
i just cleaned things up...to fit
up works no key
middle is off
bottom works with key
done this for years in many cars/trucks /vans
John
Old 07-26-2012, 11:11 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
more stock looking in the 79 and i put the switch in the ashtray
John
Old 07-29-2012, 03:36 PM   #14
RedSierra
Im new here and super happy I found this site. I Recently acquired a 1986 Red Sierra that was my dads company's work truck when I was a kid. It is in amazing condition and only has 55,000 original miles and runs great. Im trying to het power to my amp I want to install. It has the old Delco push in raido and I don't believe there is anyplace for the remote wire to go to out of the amp. So I think what I understand from these post is I need to run power to a switch and then run the remote line from the amp to that switch?
I want to bypass the stock stereo all together. Any help would be great!
RedSierra is offline   Reply With Quote
Old 07-29-2012, 05:13 PM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
that should work for the trigger and radio
just not for the main amp power
not sure what you mean
"I want to bypass the stock stereo all together"
John
Old 07-29-2012, 05:51 PM   #16
RedSierra
Thanks! I plan on running satellite radio and iPod directly to the amp.
Here is a pic of my truck!
Old 07-30-2012, 09:02 AM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
oh ok ,nice
i'd run your own ground too
from what i've seen the one for the stock radio meets the rest behind the cluster
and then goes down to one ground wire
John
Old 07-30-2012, 07:34 PM   #18
RedSierra
Thanks! Worked Perfectly!
RedSierra
Old 03-21-2014, 06:06 AM   #19
RoughKuntry
RoughKuntry's Avatar
That is how mine was set up. Only problem now is I cant hear anything from my 4 channel Boss 612ua deck. :/
RoughKuntry
73 GMC 25 HUNDRED :Sold
79 GMC High Sierra 4x4 (Ma-Duece) :Sold
99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling
88 Chevrolet Burban 2500 4x4 :Buying
RoughKuntry is offline   Reply With Quote
