Old 08-01-2012, 10:49 PM   #1
chevynova22602
chevynova22602's Avatar
Angry need brake help plez!!!!!
I have bled and bled my brakes I've even gravity bled them i can get a good pedal but I gotta pump it like crazy but if I just press pedal like normal it gose all the way to the floor
chevynova22602 is offline   Reply With Quote
Old 08-01-2012, 11:25 PM   #2
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
Re: need brake help plez!!!!!
We have a lot of smart peeps here on the forum
But maybe you can fill us on why you were bleeding you brakes
Did you replace pads ? Shoes ? Master cylinder ?
This info may lead to a resolve
JOHNORO is offline   Reply With Quote
Old 08-01-2012, 11:41 PM   #3
chevynova22602
Oh lol sorry yea I changed master cylinder
Old 08-01-2012, 11:47 PM   #4
jocko
jocko's Avatar
you didn't mention bleeding the new mc (which can be done before or after the install, but must be done).
Did you do that as part of the process?
Old 08-01-2012, 11:50 PM   #5
chevynova22602
Bench bleed ? How exactly is that done
Old 08-01-2012, 11:53 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Check this link, or Google "bench bleed master cylinder" for many more links including videos.
http://www.superchevy.com/technical/.../0509sc_bench/
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-01-2012, 11:54 PM   #7
chevynova22602
Ok thanx
Old 08-02-2012, 04:52 AM   #8
cdowns
cdowns's Avatar
i see loads of guys who bleed brakes without ever reading a factory service manual which has great step by step instructions on how to do it correctly especially what to do with the prop valve
guess that $25 is too step a price to get it right
Old 08-02-2012, 05:27 PM   #9
chevynova22602
Ok I bench bled and rebled the whole system Idk what's wrong with this flipping truck lol
Old 08-02-2012, 05:27 PM   #10
chevynova22602
Oh and still no brakes
Old 08-02-2012, 05:37 PM   #11
MrHotRod5263
MrHotRod5263's Avatar
What was the original reason for changing the Master cylinder?
What kind of problem were you experiencing before?
MrHotRod5263 is offline   Reply With Quote
Old 08-02-2012, 05:41 PM   #12
chevynova22602
Brake went out all together with no pedal at all now with new one I can pump it and get a pretty good pedal but if I just hit pedal without pumping it gose all the way to floor this has got me I've never had problems bleeding brake or changing MC before
Old 08-02-2012, 06:10 PM   #13
MrHotRod5263
in my opinion it sounds like 1 of 2 things
* there is still sir in system some where,
* or the master cylinder has an internal leak.
Old 08-02-2012, 06:48 PM   #14
chevynova22602
That may be the problem may have got a bad MC didn't think about that but thanx a lot ill let u know what I come up with
Old 08-02-2012, 07:41 PM   #15
GRX
GRX's Avatar
May still be air in the system. Only takes a very small bubble. How are the brake hoses? New? Old?
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-02-2012, 07:43 PM   #16
chevynova22602
They r old
Old 08-02-2012, 07:51 PM   #17
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Getting any air out of lines as you bleed them, or getting fluid with no air?
- Mike -
RIP El Jay
Old 08-02-2012, 07:52 PM   #18
chevynova22602
Fluid with no air I've used a big bottle of brake fluid
Old 08-02-2012, 07:54 PM   #19
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'm guessing no front discs so no proportioning valve to bleed -- correct?
- Mike -
RIP El Jay
Old 08-02-2012, 07:59 PM   #20
chevynova22602
It has 1 but no bleeder on it but I think if they go bad it just locks up the front or bk braks depending on witch side gose bad
Old 08-02-2012, 08:03 PM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I'm drawing a blank unless your new MC is bad as suggested above. No idea how often new ones are bad out of the box....
- Mike -
RIP El Jay
Old 08-02-2012, 08:33 PM   #22
chevynova22602
Well what made me think that was my buddy bought one that was bad but thanx everyone for the good advice maybe ill get it fixed if not ill replace everything from front to bk
Old 08-02-2012, 10:04 PM   #23
CEE1NG_RED
Also in the same boat... Maybe the drums has a big gap from the pads and adjusting the star adjuster may need to be done?
- 1967 Chevrolet C/10 SWB fleetside (New Project).
- 1969 Chevrolet C/10 SWB fleetside (SOLD)
- 2000 Ford Mustang 232 (DD)
- 2003 Ford SVT Cobra "Terminator" 281 (Once in a blue moon driver/weekend driver)
CEE1NG_RED is offline   Reply With Quote
Old 08-02-2012, 10:08 PM   #24
chevynova22602
Yea that may be something to look in to but I'm so mad at it rite now I don't even wanna look at at it lol but thanx I will look into that
